wheel fit question91red 10-20-2004, 09:18 AM Hi , I have a set of 15" stock aluminum factory wheels off a 1994 blazer s-10 4X4. Will these fit my 91 S-10 4cyl 2WD pickup? Thanks macbunch 10-20-2004, 09:32 AM no they won't. they have different back spacing 91red 10-20-2004, 11:35 AM Any idea how much os a spacer would be needed? lckycharm713 10-20-2004, 12:07 PM i was going to ask a question about this to, i see it here so ill ask. what is the most back spacing. i have 2wd 95 s10. i want to put wider tires on it, not little 7 inch wide stock. hunter01 10-21-2004, 05:13 PM I have a question also. Will my 15" stock aluminum factory wheels from a 1991 S-10 Blazer 4X4 2dr fit my 2002 S-10 Blazer 4X4 4dr? 83XFIRE 10-22-2004, 03:44 PM luckycharm, just go with some camaro iroc rims or something, those always look good, and they come 8 in wide. hunter, check this page out http://home.earthlink.net/~seapahn/4x4.htm That might be of some interest. lckycharm713 10-22-2004, 07:30 PM iroc rims would look ok. i kinda wanted to put on cragars and bring back the old school look. BlazerLT 10-23-2004, 10:09 AM Guys, let's not whore this thread on 91red. This is his thread. 91red, I would find some rims for a 2wd and don't go the spacer route. Iroc or camaro rims are a direct bolt on for a 4x4 and not for a 2wd. 83XFIRE 10-25-2004, 06:32 PM BlazerLT, I think it depends on if you use the fronts or the backs on the IROC rims (for those that don't know, yes it does matter). I have them on my car, but I can't remember which you would want to use. I think fronts... I don't think you can use 4x4 rims on a 2x4, but you can use 2x4 on 4x4, you just might have rubbing issues and they will stick out. BlazerLT 10-25-2004, 07:36 PM Yes, For a 4x4, 1993+ camaro, firebird and corvette wheels will fit. Automotive Network, Inc., Copyright ©2012
