shifting without using the clutch...
GT500916
10-18-2004, 11:44 PM
Today i was driving to work and i wanted to see if i could shift all the way to 5th gear without using a clutch pedal at all. I have done one gear before and it rarely goes in, but this time i got all 5 to go in without a grind at all and i didnt force it in to the gear or anything.
No there is nothing wrong with my tranny, My dad showed me this when i was about 8 years old and it interested me into how because i was never able to do it, he said you have to know the right time to shift and it will go in without a prob. No im not some 14 year old kid haha, im 23 and i can say im just bragging i guess haha, but i got to shift all 5 gears at 3,000rpm with no probs, the second gear i had to do a couple stop and goes to get in but all others went in smoothly.
This is not a habbit of mine to do this all the time, because there is a clutch for a reason, but its just a skill i have :naughty:
The reason im writing this thread is to see if anyone else has tried this, or am i the only retard around here... and i dont suggest doing this to anyone, but just saying its possible if you know what you are doing, because my friends were scaptical of this so i kinda had to prove it to them. They all have acuras and crap, so i have to own them in everything i do . :biggrin:
vsiev
10-19-2004, 12:33 AM
Ive done it before too.
logik23
10-19-2004, 02:38 AM
My dad told me about that once, like 30 years ago or whatever when he was driving a beetle, his clutch cable snapped and he had to drive around for a week and he couldn't use the clutch lol.
GT500916
10-19-2004, 02:45 AM
haha thats funny cuz when i was 8 my dad showed me that on a bug as well haha..
ec437
10-19-2004, 03:06 AM
I did it on several occasions in my bmw...
revmatching is the key.
canisay182
10-19-2004, 08:23 AM
know try to down shift all the way from fifth. its pretty cool when you know your car well enough to know a what rpm's match the gear speeds the only down fall is its pretty hard on the syncro's so i would be doing it toooo much.... just a little note
musicsurfman
10-19-2004, 09:48 AM
Synchro Killer.... Keep Doing It Nothing Bad'll Happen.
We Have A Shop Truck Here That Nobody Uses The Clutch To Shift Well One Day First Gear Was Not Exsistance So They Pulled The Tranny To Fix It And All The Synchros Were Flattend And First And Second Gear's Teeth Were All In The Bottom Of The Tranny Case.
The Only Transmissions Designed For That Type Of Abuse Is Straight Cut And Dog Ring Transmissions.
UncleBenRep
10-19-2004, 10:31 AM
ive done this from time to time too. My dad taught me how to do it in my honda. He said that truckers do this alot because of all the shifting they do and that the tranny is better suited to do it. its not bad on the tranny IF you do it right. Speed shifting tends to work at higher rpms. My dad said what to do is to give it the gas then let off so there is no tension on the gears and then slip it into the next gear. All your doing is matching up the ground speed with the tranny speed. say your doing 60 at 4000rpm in 3rd and you know that you can do 60 at 3000 in 4th then all you have to do is get it up to 4000 and then let off the gas and then slip the gear back in at 3000 rpm and it SHOULD go in pretty smooth. You feel all high and mighty when you can do it in all 5 gears....the hardest time i have is getting to go from 2nd to 3rd for some reason but other then that they all fall into place. I wouldnt do all the time because it will affect the synchro if you keep grinding the gears and such.
SR20DETpower
10-19-2004, 01:06 PM
its actually faster to shift the old fashioned way.....
maybe I can just shift lightning quick....
see when you shift like that, in terms of actual speed, you have to observe what the engine is doing and shift only at a certain time, this takes time when your waiting and looking for the right time to shift... when you use the clutch you can shift at anytime YOU want, not when the engine wants to.
Also if you know the right way to shift using the clutch and what you can and can't do, your actually using the clutch pedal for a shorter amount of time then the shifter is moving... so there is no possible way to shift faster without using the clutch, your gear changes are dependant on the movement of the shifter, which is more dependant on the design and interaction of the shift forks inside the transmission. Short shifters are just a gimmick basically... like a tornado air foil or some lil 20 dollar ebay chip. The best way to shift fast is to have a transmission designed for performance, and the 240sx's transmission is very smooth and has a nice shift gate for performance use.
learn to use your car the right way..... which is the way it was designed for... the transmissions have synchros and a clutch in them for a reason. Or you can't... and will end up spending more money on your car just for maintenance... and yes shifting like that is bad on your transmission, it is putting A LOT more wear on the parts inside the gearbox
GT500916
10-19-2004, 05:44 PM
i think we should all do this shifting without the clutch thing for a week and see who doesnt have to replace the tranny by the end of the week and that guy is the man!!!!
ok ready , set Go!!!
im gonna go do 1, 2, 3, 4, 5, 4, 3, 2, 1, without clutch tonight ont eh way to work... ill post my screw up later when i get home and how many grinds i did lol.. dont worry guys, i love my 240, just gonna do it this once, if i cant i cant ...
johnnyboy5
haha, i did that with my old 85 prelude. it was wierd, but my cousin told me it was power shifing??? wth???? He had his datsun 510 setup for that. I tried quick shifting with my prelude w/o clutch and it could do it. but it had like 285K on it so i was just waiting for the car to breakdown. (1.8L 100 hp double barrel carb :) 130 max speed) I could also do it with my 240 but i prefer not to, i could put the stick in neutral with no prob w/o using the clutch. Is this the same with u guys?
johnnyboy5
10-19-2004, 05:46 PM
hahaha yeah right, i dont have the money to get a new tranny, and i dont wanna drive my vw fox again.
Pavlo
10-19-2004, 05:53 PM
Tried that the tranny started grinding, then tried to mach the rpms nicely, shifted from 2 to 3 and then to 4th without grinding gears, my dad did that in his old car, he drove the thing for 10 years so he was really used to it and knew when to shift.
R.W.240
10-19-2004, 06:04 PM
He said that truckers do this alot because of all the shifting they do and that the tranny is better suited to do it. its not bad on the tranny of you do it right
18 wheeler drivers have to do it because they dont have syncros (double clutch :uhoh: ). it keeps the mileage between rebuilds higher.
GT500916
10-20-2004, 12:54 AM
i think your friend was saying to keep the foot on the gas without letting go and then quickly floor the clutch shift and let go , thats more like power shifting, this shifting without clutch thing doesnt realy benefit in anyway unless your clutch goes out or something lol...
and about me trying my 1-5 5-1 shifting tonight while ont eh way to work, that wasnt happening, the 1-5 i can do without any probs, but the downshifting part is different and i tried a few times but i was running late for work so i had to use my lightning fast shifting with teh clutch to make it on time hahaha... im not gonna try again, but its good to know you can do something like that.
I was actually driving tonight and i shifted from 3-4 without using the clutch and didnt even mean to NOT use it lol, so this cant become a habbit, so ill stop.
yelnatsch517
10-20-2004, 04:46 AM
You know your crazy when you can shift without looking at the tach, but only through the rev sounds.*
*I play too much need for speed underground. LOL
logik23
10-20-2004, 10:23 AM
I had to do that, my tach wasn't working for like 2 months.
musicsurfman
10-20-2004, 11:15 AM
I Can Do That At All Times.... Shifting By Sound Is Easy.
SR20DETpower
10-20-2004, 01:45 PM
lol, its like its these kids first time driving a manual car
yelnatsch517
10-20-2004, 04:17 PM
I meant without the clutch and only using sound. LOL
240sxAddict
10-20-2004, 09:33 PM
that sounds like fun damn auto tranny but i can change gears with my tranny still... even if its a/t.
Murherar
10-21-2004, 08:05 PM
i feel you sr20
Pavlo
10-21-2004, 09:38 PM
do you guys actually look at tach? I never do that my dad tought me not to look there (i did at first) it just gets your attention off your driving. 240sxaddict I feel your pain, used to drive my dads auto sentra damn thats boring.
logik23
10-21-2004, 10:51 PM
I learned to drive stick without a working tach so I never look at it.
zexel42015
10-21-2004, 11:00 PM
That is pretty cool i had neverheard of that i dont think i would try that.
zexel42015
10-21-2004, 11:04 PM
that is to risky if you ask me
nissanfanatic
"Granny shifting, not double clutching like you should. You're lucky that hundred-shot of nos didn't blow the welds on your intake!"
Had to do it. Don't count on your transmission to like this kind of driving. I have done that before, but now I would rather just shift normal to preserve the transmission for when I do race and so I can hear my BOV.
SHIFT_KA24DE
10-21-2004, 11:09 PM
If engaging the clutch is that much of a hassle... Buy a damn automatic... there are others out there who prefer a m/t anyday.
Chuki_breath
10-22-2004, 12:01 AM
it did blow the welds on my intake but i had a double quattro super cool fogger 200hp shot thats y it happend.
GT500916
10-22-2004, 12:18 AM
lol we are not here to find a way not to use the clutch... just saying its a skill not everyone knows how to do, and if you can do that by listening to the rpms and stuff then you are a good drive and know whats going on... FUDGE AT!!
SR20DETpower
10-22-2004, 07:44 AM
[QUOTE=nissanfanatic]"Granny shifting, not double clutching like you should. You're lucky that hundred-shot of nos didn't blow the welds on your intake!"
QUOTE]
LMFAO NP MAN
FAST AND FURIOUS QUOTES RULE
granny shifting not double clutching.... it was almost like their transmissions didn't have synchros HAHAHA
Murherar
10-23-2004, 08:24 AM
you are the man sr20, maybe i will be skilled enough one day when i want to shift without using the clutch and mess up my transmission...
nissanfanatic
10-23-2004, 10:23 PM
What are you talking about? You know they all had either Holinger or Quaife six-speed sequentials custom made to fit thier cars.lol Do you know what a 100 shot of nos can do to your tranny welds?hahahaha Make sure you double-clutch and don't granny shift or you'll be sorry. Ask any racer, any real racer.HAHAHA I'm out.
logik23
10-23-2004, 10:47 PM
I know you're joking (or at least I hope you are), but they had real manuals in the movie, none of this sequential bullshit.
orestes
10-23-2004, 11:08 PM
i <3 paddle shifters and SMG's. y'all heard about the new M5? its SICK.
logik23
10-23-2004, 11:36 PM
SMGs are gay, soon, no cars will have real trannies, they say it'S because they couldn't make a tranny strong enough that had a normal shift pattern, I say, if the Viper has a real tranny, why can't BMW do it?
SR20DETpower
10-24-2004, 05:58 AM
hey hey, real sequential transmissions KICK ASS, of course they go for 5 figures though too...
Murherar
10-24-2004, 12:08 PM
yeah sequentials are super expensive..
Pavlo
10-24-2004, 12:14 PM
there are kits that convert your manual to sequential, but it kind of gets the fun out of driving, great for drag though. Still have more controll with stick, clutch can help a lot during driving, like when you want to do a 180 from stading position you just rev turn the str wheel and pop the clutch, I wonder how to that with sequential...
back to topic since I don't have a 240 right now (unfortunatly) i tried it on a civic that thing just screams, does not let you shift unless the rpm are really percise.
