Coutesy Lights too dim!!??fuzzydice 10-18-2004, 02:48 PM On my 2001 GTP, the courtesy lights above the rear doors seem dim (also the dome lights). Are there aftermarket bulbs that could be used to increase the output, or maybe I could use LEDs? richtazz 10-18-2004, 04:32 PM The GM computer isn't real clear as to what bulb that fixture takes, but I'm sure you can buy brighter aftermarket replacements kustomkid54 10-18-2004, 05:46 PM New car? Where they brighter at one time or always dimmer? I would check if they are as bright as everyone eles. You may have a bad ground. Pull off the plate and check the voltage. Went to storage and checked out my GT. Their bright enough to read by. (GTX only has 2 doors). richtazz is right they do make brighter lights. But it's always nice to check. Good luck http://img.photobucket.com/albums/v425/kustomkid54/1998PontiacGrandPrixGTP004.jpg fuzzydice 10-18-2004, 07:15 PM Thanx for the response. I'll check the voltage and see what's up. I'm thinking I can check the GE Bulb catalog and see if there's another bulb that's rated for more candlepower with the same base. kustomkid54 10-18-2004, 08:16 PM Putting new bulb in will more then likely give you a little more light. But if it's a bad ground, your light that is in there will give you more light. Then change if you like. http://img.photobucket.com/albums/v425/kustomkid54/1998PontiacGrandPrixGTP003.jpg Automotive Network, Inc., Copyright ©2012
