96 Buick Skylark
killjoy606
10-17-2004, 11:43 PM
My buick will start sometimes but most of the time the car will turnover, idle for about 2 seconds, then die. I've taken it to many dealers, they've put on a new starter, new carb, new fuel pump but nothing has worked. When the car does start, it runs just fine. There is no telling when it will or won't start. Any clue as to what it could be?
tman
10-18-2004, 07:26 AM
If they put a new carbuerator on, you need to find a new dealer, because theres no way that engines not fuel injected
skiCrazie
02-04-2005, 06:39 PM
I have a car with the same problem. It's been to practically every shop in Baltimore that services Buicks ( it used to be my grandparents) and the most recent shop made it run for the longest it has ever run - a whopping 5 months- by replacing the dash board. they said it was the anti theft device shorting itself out. of course it is once again not working and has spent a very large portion of the last four weeks in the shop and it is currently stuck at school.
skylark96
02-25-2005, 02:46 PM
I have a car with the same problem. It's been to practically every shop in Baltimore that services Buicks ( it used to be my grandparents) and the most recent shop made it run for the longest it has ever run - a whopping 5 months- by replacing the dash board. they said it was the anti theft device shorting itself out. of course it is once again not working and has spent a very large portion of the last four weeks in the shop and it is currently stuck at school. MY car just started to have the same problem my shop is telling me that its the anti-theft system as well They told me I need a Key with a Chip or a code I have never had one I had the car since 1998 I will let you know what it is
skylark96
03-18-2005, 11:36 AM
[after the shop having my car for 3 weeks the said the my airbag module was shorting out the IPC. I have a leak and the airbag module was wet. Now I have to find the leak.
kdonnelly
03-30-2005, 10:08 PM
I just bought a 96 skylark and it has the same problem. It will start but just stalls automatically, unless the dash lights come on when you turn the key, it will not start. I bought from a mechanic, who cannot figure out the problem. Mechanic bought car from auction. If anyone knows the solution, please let me know!!
m_klepto
12-11-2005, 04:21 PM
My 96 Skylark is now having this same problem. The Mechanic replaced the MAS (Mass Airflow Sensor)$240 parts&labor and then it started working again.. Now 2 1/2 months down the road it started doing the same thing again
