OEM Fog Lights.HLBK 10-17-2004, 10:37 PM Hi everyone, About three weeks ago I purchased '04, HL without factory fog lights. I was wondering if anyone had bought OEM fog light and installed it. How much was it? Would I need any additional brackets? Is HL prewired for fog lights? Any response would be greatly appreciated. Thank you. kathygarnerville 11-13-2004, 03:45 PM I have factory installed ones on my Highlander, as well as on my two other cars (a Jeep Grand and a Sebring), and honestly, they don't do much help when I need them. On the highlander, they are so easy to forget their are on, that's how dim they really can be. Your highlander doesn't need them, and, check with your state DMV. In some states there are special regulations on when to use them or not yowmahmen 11-28-2004, 06:01 PM Quoted from ibleedblue of TundraSolutions.com Forums " Finally...this is a copy and paste of directions I've sent to others. Sorry, but I don't have any pictures. I didn't take any during the install for whatever dumb reason! Just for the sake of being safe, you should disconnect the positive lead from the battery. The hardest part of installing the fog lights is taking off the cover of the steering wheel column. You have to replace the headlight switch with a new one, that's why the cover has to come off. The steering wheel itself doesn't come off, just the cover around the column. Follow this link and look at page 5. The instructions in the link are for installing the RS3200 system, but page 5 shows you how to get the steering wheel column cover off. Don't worry about taking the kickplate off like the first picture shows. You don't have to do that. Once you get the cover off, you'll see where the wiring harness is plugged into the headlight switch. Take the harness out, then take the switch out by pressing the black claw tab in the middle of the square part. The new switch goes in place in reverse, and then you can put the column back together. Make sure you push the switch all the way back in. I didn't at first and the turn signals wouldn't turn off after I went around a turn. I pushed the stalk on the headlight switch really hard and I felt it pop in place and it's worked fine since. To get the filler plates in the bumper out, just take a screwdriver and start prying the from the sides. Be careful not to scratch the paint on the truck. Once you get the plate moved just a little bit you can pull it out. It's plastic and bends very easily. Just FYI, I sold these on ebay and got $15 for them. So take them out carefully and make a little cash if you can! The wiring harnesses for the fog lights are taped to the headlight harness assemblies above. Cut the tape and feed the fog harnesses down to the holes in the bumper. The fog lights use a type 9006 bulb. You can get them from Toyota or just go to Autozone and save some $$. You can use the blue and purple colors if you want, but if you go with no tint, don't get anything higher than 55 watt. I'm not sure the wiring harness is built to withstand any more heat than a 55 watt would create. So now plug the bulbs into the fog light assemblies and lock by turning whichever way is printed on the fogs. Plug the harness into the bulb and push the fog light assembly into the hole. It will be obvious which way and which hole the fog assemblies go in. The little black tab snaps into the little hole on the bottom side of each fog light hole. Don't worry, that'll make sense when you see it. The fog lights don't take up the entire hole, so you put the protectors on around it. Those just snap in place. Now the last thing to do is put the relay in. This is what took me forever to find! I wound up calling a dealership and getting some help. OK, see that little change box on the drivers side kick panel? Let that down and then pull up on it to get it to come loose then take it out. You should be looking at the fuse panel now. The relay goes on the BACK of the fuse panel. Reach up from the bottom of the fuse panel and just feel around on the back of it (you won't get shocked). The relay goes on the bottom row, in the middle slot. It should be the only slot open on the bottom row. Plug it in, put the change box back in place and you're done! Here are the part numbers. The cheapest place I could find online was toyotapartworld.com. Check some other places or call some local dealerships and see where you can get them the cheapest. These lamps don't take up the entire hole for the fogs, so the protectors are required. There may be other lamps available too, but if there are I don't know what they are. 81211-52070 RH Fog Lamp 81221-52070 LH Fog Lamp 90981-13047 Fog Lamp Bulb (you can get these cheaper at AutoZone, Pep Boys, NAPA, etc.) 81483-48010 Protector (req 1 per side) 90987-02027 Relay 84140-20680 Switch " " Toyotapartsworld.com quoted me ~$350 + shipping. Someone else that I've given these directions to emailed and said he had found a cheaper online Toyota parts house, but I don't know which. " Automotive Network, Inc., Copyright ©2012
