Engine starts but if in gear it stalls
mfaulkrules
10-17-2004, 06:00 PM
I have a 1994 dodge ram 1500 with a 5.2L.
Ok it will start "ok" but if i put it into gear any gear it will stall. I found out if i put it in neutral then start it the put it in drive really fast and keep pressing the gas it will stay moving and not stall but if im at a stop light or sign it will stall. Anyone know what is causing this?????
LTJGWorth
10-17-2004, 06:32 PM
Could be TPS, or some sort of valve in the throttle body (i forgot what the valve is called). Also, check your tranny fluid. There could be a problem with the torque converter lock-up. The clutch might not be releasing.
BamaDodgenMX
10-17-2004, 09:44 PM
If the rpm's drop immediately when put in gear.. I have the same problem, and am still searching for a fix.
