1994AccordDX won't start..need helppnoppaku 10-16-2004, 06:27 PM My car is weir! It happen monts ago. It's crank..but sound like there no gas's catch. The car won't start...but after several hour..It's start! Now it happen again in couple a few day. I can't figure out what's wrong. Please help! pnoppaku 10-16-2004, 06:28 PM I'm confuse ? derecka1 08-10-2008, 10:34 PM it could be your fuel pump main relay. check the fuel pump relay located under the dash board on driver side up the teering colum. take it out open and resolder all connections. or buy new one. your car should start. jeffcoslacker 08-11-2008, 12:02 AM Buy a can of spray starting fluid. Next time it does that, shoot it into the intake. If it starts up on that and dies again, it's for sure a fuel problem. Check the relay, fuel pressure regulator, etc. If it doesn't try to start on spray start fluid it could be a main relay, ignition switch or any of a dozen other things...you'll have to figure out if it's spark or fuel related before going further... One tip, if the ignition switch is going bad, you can usually turn the key slightly back and forth in the run position while the motor is running, and it'll shut down. somick 08-11-2008, 01:20 PM The thread is FOUR YEARS OLD!!! Automotive Network, Inc., Copyright ©2012
