power door locks
boats001
10-15-2004, 01:42 PM
I need some info on the power door locks on a 2001 dakota. I need to know if thety work off a 12v negative system or a 12 v positive system. I am installing a remote starter and a keyless entry and I need to know if they work of a pos or neg system
Thanks
diabloed
10-15-2004, 03:01 PM
I think you might find this information quit usefull.
12volts pnk/blk & red/lt blu + ignition harness
Starter yellow + ignition harness
Ignition blue + ignition harness
Second Ignition green/red (18 ga) + ignition harness
Accessory black/orange + ignition harness
Second Accessory green + ignition harness
Power Lock white/green - conn. 2, pin 10 @ CTM
Notes: Lock is negative trigger thru a 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
The Central Timer Module is in the driver kick panel.
Power Unlock same wire
Parking Lights+ black/yellow headlight switch
Parking Lights- red/yellow conn. 1, pin 4 @ CTM
Notes: The Central Timer Module is in the driver kick panel.
Door Trigger - CTM
Notes: The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears on the 4dr) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information. The Central Timer Module is in the driver kick panel.
Dome Supervision use door trigger
Factory Alarm Arm lt. green/orange - conn. 2, pin 14 @ CTM
Notes: Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger thru a 1565 ohm resistor. MUST use relays. This wire will also lock the doors, and it will unlock with a double pulse.
Factory Alarm Disarm same wire
Tachometer ignition coil
Notes: On the 2.5L/3.9L/5.9L models use black/gray at the ignition coil. The 4.7L models have an ignition coil for each cylinder, use the wires that is NOT green/orange at one of the coils.
Brake Wire white/tan + brake pedal switch
Horn Trigger black/red - steering column or CTM
Immobilizer Bypass Module: Required: Yes Type: Sentry Key Part #: 555C, 556U, or 555U
Notes: Only vehicles with gray keys have the immobilizer.
If you have any question feel free. I have a 03 Dakota and I'm a certified installer.
