2000 S-10 stuck on "vent"
BAKEDIDDY
10-15-2004, 10:42 AM
We have a 2000 S-10 Pickup with A/C that is stuck on "vent". You can turn the knob to floor, or defrost and it still only blows out of the vents.
Any ideas?
Kevin
:biggrin:
movin2stereo
10-15-2004, 09:31 PM
Switch?
busa_4
10-15-2004, 10:42 PM
i think the 1998 blend doors are still vacuum actuated. if you have a vacuum leak the blend doors will not change and they will stay in there nuetral setting. i dont think the nuetral setting is center vent. it should be defrost and floor. if it is a vacuum system remove the glove box and check all the actuators to make sure there holding vacuum. if they are, then you need to check if they are getting a vacuum signal. there should be a distribution block by the actuators with solenoids on them and vacuum lines going through them. each actuator is controlled by a solenoid. make sure the solenoids are working. once again i am unsure if this year is a vacuum system or motor controlled. the motor system is similar but symplified. the motors take the place of the vacuum actuators. make sure the motors are working. also check the switch as movin2stereo recommends. that problem is more common on the newer blend motor systems. hope this helps and doesnt confuse you. good luck!
boneil
03-23-2005, 10:48 AM
Any ideas?
Kevin
:biggrin:
Kevin,
Did you ever figure out what the problem was and how to solve it? I am having the same problem with my 02' ZR2 truck. I have replaced the control units (speed,heat/cool,ventspd) and it worked for a week then went back to stuck on vent. I am getting very anxious to fix this problem. If you could let me know that would be great.
Thanks, Bryan
Email: bryanoneil8@yahool.com
dmbrisket 51
03-23-2005, 03:48 PM
ok, your a noobie, so well let it go this time, please start a new thread on the subject and we will be happy to answer, as long as you searched and didnt find an answer first... see the 10-15-2004 under "posts" for busa, that mean the last time anyone replied to this b4 you was october of last year, thread is old and the people in old threads dont alwase have their s 10's anymore (mostly due to resale and car crashes, not poor craftsmenship) so please click new thread at the top of the s 10 page, and we will be glad to assist you with your problem
