2000 S10 Cigarette Lighterbreakaway_sparky 10-14-2004, 08:52 PM :smokin: I keep replacing fuses in the cigarette light. Everytime I replace a fuse and attempt to use the lighter it blows a fuse. Could the lighter itself be bad or another cause. :banghead: breakaway_sparky 10-14-2004, 08:55 PM Does anyone has a solution to my problem blowing fuses in lighter Mikado14 10-14-2004, 10:05 PM The Lighter plug has probably gone out to lunch and it will need to be replaced or you will blow another fuse and then another etc. If you have another car you can steal the lighter from, try that and see if it still blows fuses. If it doesn't, then you only need the lighter, usually they just quit. If it blows the fuse, then the first paragraph is your answer. Good Luck! Automotive Network, Inc., Copyright ©2012
