Idle/Tach drops suddenly almost to zero95path95 10-14-2004, 04:49 PM when stopped but accelerates smoothly. Doesn't do it every time. Just started last week. Any ideas greatly appreciated. airboatphil 11-01-2004, 08:03 PM while parked, at idle...will it act up on its own ? If so, monitor the ign. coil negative terminal with a test light....the light should constantly flicker while engine is running right.........if it goes steady at anytime and engine speed decreases, the module,pick-up, crank sensor or ECM may have a problem. If the light continues to flicker even while engine speed is decreasing...look at the rotor and cap. Phil 95path95 11-03-2004, 10:42 AM Thanks for the tips airboatphil. Walt Automotive Network, Inc., Copyright ©2012
