How to Install Indiglo Gauges on a Del sol??
Lonely SOl
10-13-2004, 11:54 PM
Hi Does anyone know any web-site that has step by step installation of reverse gauges for a Honda Del sol. If anyone has any info about this installation , If you woud let me know, I would reaaly appreciate it, thank you
AudioGuy93DelSol
10-14-2004, 05:28 PM
I can tell you how to get the gauges out, i did whne i put my VTEC light in.
First get a flat head screw driver and pop out the switches on both sides and unplug them the plugs are differet so dont worry about lableing them. Then remove the 2 screws underneath the bezel, and it will pop out (there are 3 metal clip holding it dont lose them cause they like to fall off) Now pull out the dial for the dimmer and the Odo. reset button(the whole shaft comes out with that) hmm now im thinkin there is one screw that holds the cluster in right in the middle, there might be one on either side also, dont remember, after those are out you can unplug the 2 big wire harnesses and thinks there a seperate wire for the clock. now you should have the whole cluster out The front and of the cluster detaches from the back with 6 screws i think and a bunch of plastic tabs that you have to carefully pry one by one and clowly pull it apart, they like to break if you even look at them funny so be careful. That should be it. IF you can attach some wires im thinking it souldnt be that hard to put the gauge faces on. Hope that helps.
