no speedo or cruise
ral3ph
10-13-2004, 05:58 PM
hi i have a 00 ram and the other day i noticed the brake light and abs light was on then the speedo wasn't working so cruise isn't working either,any ideas anybody.
thx chris
LTJGWorth
10-13-2004, 08:37 PM
Your problem is your ABS sensor in your diff. It's on the top of the diff case. You'd better get it checked quit.
scoutinkeith
10-14-2004, 01:32 PM
yep, sounds like the rear axle ABS/speed sensor.
it is magnetic, so when you pull it out to change it, take a look at the amount and size of shavings that are on it. if there are a lot, it might be a good idea to change the dif fluid wile you're at it.
ral3ph
10-14-2004, 05:18 PM
i can see it on top of diff but have no idea how it comes out,do you by any chance.
thx
LTJGWorth
10-14-2004, 08:41 PM
If i remember correctly, there is a retaining clip that's held onto the case with a bolt. All you have to do is take out the bolt and the entire thing pulls out. I've only taken mine off once and that was to fill the case with fluid.
mxracer111
10-14-2004, 09:51 PM
changed mine the other week, like they said, take the bolt off and when pulling up twist a little, theres a rubber o-ring that helps seals, i paid 41 bucks w/tax for the oem replacment, the ones at auto store looked diff and cost the same price. plus dealer should have in stock, i went in and asked for the part and he knew what i wanted. said thats pretty common. when reinstalling spray some slippery stuff or some lube on o-ring to install easier and wont rip o-ring
BleedDodge
10-14-2004, 10:34 PM
Check your fuses as well.
ral3ph
10-15-2004, 12:20 PM
ok i've got the bolt out,does the whole thing come out of the diff,i've been twisting it but it won't come out.oh and another ? how does the conector come off icant figure it out.
thx for your help
LTJGWorth
10-15-2004, 04:48 PM
You may have to do a little prying on it to get it out, but it just slides right out after the bolt is off. I'm not sure about the connector. Should have a button on it that you push to release it. Then again, i've messed with connectors on my truck that had little plastic pins in them to help hold them in place.
