wierd soundpyromania18 10-13-2004, 12:44 PM i have a 91 4x4 4.3L S10 Blazer and when i am in reverse or making sharp turns there is this sound coming from my rear left tire thats kinda like a clunk noise, does anybody know what this could be busa_4 10-13-2004, 02:50 PM check your suspension bushings. they are probably rottted or damaged to a point that they are cracked or missing. how does the vehicle drive? does it pull when you brake? does it wander when holding the steering wheel straight? do u hear clunking noises over bumps? do u have a wear pattern on the tires? BlazerLT 10-13-2004, 02:53 PM Yip, or your rear drum brakes are falling apart. Mikado14 10-13-2004, 10:18 PM Jack each side of the rear of your vehicle up and check side to side wobble and in and out play. You are checking for a bad rear axle bearing. pyromania18 10-13-2004, 11:38 PM the only one it does out of those is the clunking noises over bumps, but thanks guys this helps a lot Automotive Network, Inc., Copyright ©2012
