qick question re:rb26dett
GODZILLA
06-04-2001, 09:56 PM
could a cracked boost hose from the intercooler be causing misfure constant flatspot and more lag thats the problems im having but to check i have to pull the the front bar of its a r32 before i start does this sound right
thanks in advance
SkylineUSA
06-05-2001, 06:46 AM
Hey Godzilla,
Yes, it could be caused by a cracked hose if it does not alow the boost to pressurize the manifold. Could you use a couple of commas, it's kinda hard to read your posts. Maybe its just me, but it all seems to run together.
misfure? was that misfire? I have always thought of misfires as a timing problem, sence your getting spark when the valves are open. Maybe someone else can shed some light on it for you. Good Luck:)
GODZILLA
06-05-2001, 10:49 AM
yeh sorry misfire as for the timing, there are are 7 marks and its on the second. What should it be on or what do each mark represent is it 10degres , and should it be on 20 degres advance.
thanks for your reply.
SkylineUSA
06-05-2001, 12:15 PM
I do not want to give you any information that is not absolutely right, but I would come up with the same assumtion that your on the 20deg mark.
Have you tried posting on www.skylinesdownunder.co.nz ?
