89 S-10 Blazer 4.3 Rough Acceleration
89blazer
10-11-2004, 06:22 PM
I just bought a 1989 S-10 Blazer 4.3 V6 Auto with only 100K miles on it. I test drove it cold and it was decent. Once it's warm though, the acceleration and idle are very rough while in drive. Engine idles very smooth in Park & Neutral and revs smoothly. I checked the trans fluid and it's way over filled but clean and fairly odorless. Would being over filled cause the problem or is it over filled to hide a worse problem? Does it need a new tranny? Is this typical of these? I spoke to a friend with a 91 Astro van with a 4.3 and he's gone through 4 trannys already. Argh! Thanks in advance...
Mikado14
10-11-2004, 07:41 PM
IMHO, your comparing an apple to an orange as far as the Blazer and the Astro Van are concerned.
As to the overfilled tranny, if you see no leaks or you don't have evidence of oil from the tranny in the antifreeze, than the person just overfilled it. Wouldn't be the first time I have seen that one.
Now, about the rough idle. Do you have any codes or is the MIL lighting up?
Did you do a tune-up since you purchased this vehicle? When was the last time the previous owner did a tune-up?
I would do a tune-up first. Plugs, wires, cap and rotor, fuel filter, air filter and PCV.
89blazer
10-11-2004, 07:56 PM
Thanks for your input, Mikado (not sure what IMHO means). The seller just tuned it up with plugs, wires, cap & rotor. He said the plugs were nice and gray, all the same color. I'm pretty sure it's not the engine because it runs fine in neutral and park and revs real smooth. But when it's warm, putting it in drive makes it run rough and accelerate rough. When on the freeway it runs smooth. Just at idle and acceleration it's rough. I don't know what the MIL is and where would I see codes?
Mikado14
10-11-2004, 08:23 PM
IMHO = In My Humble Opinion
Here's a few things you can check.
EGR, remove and clean. Your EGR should be vacuum actuated and the diaphragm may be ruptured. To check, unplug the vacuum line and plug the vacuum hose with something that will fit, a sharpened pencil will work. Start the car up and see if there is a difference.
Air Filter, replace
Fuel filter, replace
Fuel pressure, check - If you don't have the guage, ask around with some of your friends.
The MIL is the "check engine light" it stands for "Malfunction Indicator Lamp". If this lights up, the computer has detected a fault and has stored a code. You will need a code reader to retrieve it. If you are close to an AutoZone, they perform this for free. And they may be able to check your fuel pressure as well.
89blazer
10-12-2004, 01:00 PM
Great, thanks!
OverBoardProject
10-13-2004, 01:24 AM
The Oxygen Sensor is often overlooked, and could easily cause the problems you mentioned making the computer think that it's running lean, or rich
Mikado14
10-13-2004, 10:16 PM
If the O2 sensor was at fault, there would be a code and the MIL would be on. You are correct in that a bad O2 may not show up until the engine is warm and the ECM goes to a closed loop condition but then again, a light would be on and he has not answered with that info.
89blazer
10-14-2004, 11:43 AM
Thanks guys. I've been able to duplicate the vibration in Park so it's definately not the tranny. If I rev to 1500 RPM and hold, I can feel kind of an out of balance type harmonic vibration in my seat. I think maybe the exhaust pipe or muffler is touching the floorboard or I have a broken motor mount.
89blazer
10-22-2004, 12:49 AM
Okay, I disconnected the vacuum line from the EGR valve and the roughness still exists once warmed up. No change. However, there was no vacuum present on the line when I disconnected it. This has an EGR solenoid in-line between the throttle-body and the EGR valve. How would I verify that's not the problem without replacing it? There's good vacuum on the feed line to the solenoid but the guys at the auto supply said it's impossible to test in the driveway. It only comes into play under certain driving conditions. Also, how do I tell if the diaphragm is bad on the EGR valve once I remove it...see if it will hold a vacuum on my tongue? I just thought of this -- my temp gauge shows 200-210 during normal operating conditions. Isn't this a little hot? Would you recommend a cooler thermostat, or none at all (this truck runs great when cold).
quaddriver
10-22-2004, 01:41 AM
the guys at the auto supply are weenies.
get a vacuum gauge, hook up to the EGR side of the solenoid, then when warm, slowly increase the rpms in neutral. the solenoid will open after 1500 rpm and it you nail it past 75% the solenoid will close again.
that will prove the solenoid.
next use a vacuum pump (with gauge) hooked to the egr and pull some vacuum. it should hold for at least 5 seconds before bleeding down (it actually should hold for hours, but slow leaks can be tolerated)
BlazerLT
10-23-2004, 10:15 AM
BTW, have you changed the fuel filter lately?
Sounds like it is starved for fuel.
89blazer
11-03-2004, 09:13 PM
Replaced the fuel filter, put a 160 thermostat in, cleaned the EGR valve (it was hardly carboned up and held vacuum indefinately), I wasn't getting good readings on the EGR solenoid so replaced it, flipped the air cleaner cover over for more air -- no difference :-/. Next items: change PCV valve, check fuel pump pressure, check spark plug gap. What else would change once warm and cause it to bog from idle to 2000 RPM? I'm also thinking clogged cat (anyone know where to get a cheap cat?). Any other ideas?
BlazerLT
11-03-2004, 09:16 PM
160 stat will do it.
180 is the lowest you should ever go.
89blazer
11-04-2004, 02:03 AM
The reason I'm trying the 160 stat is because it runs like new when cold, nice and smooth with good power. As it heats up, the idle gets rough, near stalling, and mild acceleration is rough and labored with a vibration. If I stomp on it or get over 2K, it runs smooth. I was convinced it was EGR related. This is frustrating as I spend most of my time in traffic under 30 mph when it's most prominent.
BlazerLT
11-04-2004, 03:28 AM
remove the 160.
It is not allowing the engine to get up to temperature and probably not allowing your engine to go into closed loop.
Mikado14
11-04-2004, 10:44 AM
Heck, if your gonna go to a 160 you might as well run without a thermostat. That way the engine will always run open loop and you won't have the problem.
89blazer
11-04-2004, 10:55 AM
I pulled the PCV valve out of the valve cover this morning and just left it hanging and the symptoms improved. Any feedback?
89blazer
11-04-2004, 10:57 AM
I don't know what you all mean by closed loop. Is that my problem?
Mikado14
11-04-2004, 08:35 PM
Open Loop operation, in a nut shell, is when the engine is cold and the computer is operating off of default settings and is not taking any corrective measures. When the temperature comes up to operating temp, around 160 to 180 max, the computer reads conditions from your sensors (inputs) and will correct accordingly.
Basically, on your '89, the "loop" is the reading of your sensors to affect the timing and the fuel delivery. When it is open, the computer is not changing the timing or the fuel, it is operating on default (open), when it is closed, it is.
89blazer
11-04-2004, 08:42 PM
Replaced the PCV valve and it fixed it. Damn, why didn't I try that first. You named it in your first post Mikado. Thanks for the help guys. Now I gotta sweet talk the auto supply into taking that $60 solenoid back and put the 195 stat back in. Would I benefit from a 180 stat over the stock 195?
Mikado14
11-04-2004, 08:54 PM
Why would you want to run a 180 instead of the stock 195? The prom in your ECM is programmed for that thermostat. Therefore, I would say leave it stock. The ECM will relearn to operate at the lower temp but it won't be as efficient. Anyway, you may find the heater won't be as hot, LOL.
89blazer
11-04-2004, 09:54 PM
I've heard you can get more HP with a 180 but I guess that's with a performance chip written for that temp. 195 it is. Hot heaters are good...
Mikado14
11-04-2004, 10:05 PM
Yeah, heat is goooood this time of year. Have a friend at work with a Hyper chip in his '91. I calls for a 160 thermostat. Every winter he pulls the chip and changes the thermostat to 195. Why? His feet get cold, go figure.
BlazerLT
11-04-2004, 10:44 PM
Although 195 is the stock recommended temperature, the computer will still go into closed loop with a 180 stat in.
Mikado14
11-04-2004, 11:03 PM
Here in Pennsylvania we have emissions testing. You learn awfully quick how a colder engine won't pass the emissions testing even though the computer relearns. Also, I stated that it would relearn. He's better off with the stock thermostat.
BlazerLT
11-04-2004, 11:10 PM
Here in Northern Ontario, Canada where it goes to -40f we run 180f fine and dandy with no problems.
uummm
11-20-2004, 08:13 PM
you said the engine gets up to 200 or 210, that isnt good for the motor, id have the coolant system checked if the stat didnt help any, and it almost sounds like you are losing vaccum from somewhere, id get a tester for that and see if infact you are losing vaccum, other than that, my only other idea would be the fuel filter being clogged somewhat, enough that when you put it in gear, the transmission puts enough strain on it to bog then engine. thats all i can think of
-Ryan-
BlazerLT
11-20-2004, 10:51 PM
200-210 is not bad for our engines at all.
Mine sometimes gets up to 200-210 in the summer time.
Hell, the stock stat is 195, how is 200 a big deal?
uummm
11-21-2004, 12:56 AM
well, i just thought when the temp of a car gets that high, that it would overheat, i have a 185 thermostat in mine though
BlazerLT
11-21-2004, 01:28 AM
No such thing as a 185 thermostat, only a 160, 170, 180 and 195.
Stock thermostat temperature is 195f.
uummm
11-21-2004, 11:17 PM
i dunno, i just went off of what my dad told me, he is the one who replaced it, maybe it is a 180
BlazerLT
11-22-2004, 12:36 AM
180s would be fine in all climates except the ones that get very cold in the winter, say 15f and lower.
