Outside Temp. Sensor/compass
GIBBLER
10-10-2004, 07:41 PM
I Have A 1998 Chilkoot Pathfinder The Compass And Outside Temperature Readout Would Stop Displaying Intermittantly, Then They Stopped Displaying Altogether.
I Believe I Have Located The Temp. Sensor Behind The Front Licence Plate, I Have Removed It Checked The Connection And Put It Back On Again This Did Not Solve The Problem, The Dealership Said It Is A Common Problem And I Can Bring It In For Them To Source The Ground Wire!! This Will Cost An Arm And A Leg! Has Anyone Found The Cause Of The Problem On Their Own?
macphisto
02-09-2005, 11:29 PM
I don't have an answer to your problem but I have the same vehicle and prob myself, mine does not work at all help
infinman
02-10-2005, 07:30 PM
Make sure 10amp fuse{#9} is ok.If ok remove compass unit and tap into black wire at connector and ground to body close by.If that don't work your unit is faulty.
98-4runner
02-11-2005, 10:10 AM
I have a same truck and it got the same problem, some time on and off by itself. you have no control on it but just by luck.
98-4runner
02-15-2005, 10:21 PM
i tried to replace the fuse #9. it doesn't work either. if the unit is fault, why some time it works and something doesn't. it guess it might be something wrong other than the unit.
does anyone know how to fix it?
