1984 Supramkiiogg 02-16-2002, 07:22 PM When you have adjustable cam gears and running performance cams (GUDE), what is a good degree to set each cam at? Knowing that when setting the cam either A (Advanced) or R (Retard) ONE notch equals 2 degrees at the crank! I've heard 4 degrees advanced for the intake and 4 degrees retard for the exhaust! Does that mean move the gears two notches to get 4 degrees at the crank or move the gears four notches to get 8 degrees at the crank? Very interesting question to be answered! -Greg- MA61XXGTE 03-02-2002, 03:51 AM Originally posted by mkiiogg When you have adjustable cam gears and running performance cams (GUDE), what is a good degree to set each cam at? 2 words.......Dyno tuning. You'll thank me in the end. Whats the lift and duration on those cams of yours? Are you asking about a 5M-GE? Automotive Network, Inc., Copyright ©2012
