Problems
bclipse
10-08-2004, 05:44 PM
Ok well my car is acting up i think it might be the mas. Here is what it does there is a delay in the gas pedal, but the timing is right on. It smells like gas so i think the injectors are messing up.I need your help to figure out what it is.
bclipse
10-08-2004, 05:48 PM
Oh and it has trouble getting past 2500 rpm's, but when it does get over 2500 it revs real nice
xavier3jr
10-08-2004, 06:08 PM
i had the same proablem with a 1986 toyota pickup i figured it was the fule injectors to cuz it wouldnt take gas so i put fule injector cleaner in it got it down to about hafe a tank ridein down the inter state and m whole exhaust just blew off from under the car sounded like someone sitin in the passenger seat shot a 12 guage out the window it was so loud......so just dont put fule injector cleaner in it lol
guitarXgeek
10-08-2004, 06:12 PM
Check your plugs and wires, and make sure the plugs are gapped correctly.
1stGenRocks
10-08-2004, 09:44 PM
hey xavier it sounds like that pickup had a clogged up cat. lol we had a civic at the shop i work at, the chick who owned it thought it needed oil so she added 4 quarts. lmfao it was smoking like crazy, clogged up the cat, fried the o2 sensor, fouled the plugs.... lesson learned, dont add 4 quarts of oil to a engine unless its empty.
as for your problem i would check for a boost leak. also pull the intake pipe off going into the throttle body and see if its all black inside. if it is thats carbon from the pcv which will foul up the intake system. clean it with some cleaner the cheap shit from autozone will work fine. make sure to open the throttle and get as far in as you can.
bclipse
10-09-2004, 10:37 AM
The throttle body was pretty clean, what i want to know is what would put that delay on gas pedal its like when im letting off the gas thats when it starts to rev up
GTracer1618
10-09-2004, 10:42 AM
iv had the same problem be for except on my 3000gt and it defienatly sounds like you need your fuel injectors cleaned.. my car did everything ur sayins urs is doing i went and had them cleaned (power washed pretty much)and from then on it ran great..
bclipse
10-09-2004, 02:08 PM
Thanks man appreciate it
