Brake Rotorstcolbyii154 10-08-2004, 02:42 PM Is anyone having problems with brake rotors on their Dakota's from 2000-2003. I am on my 4th set ready for my 5th. They seem to warp very easily, any suggestions? Magm16 10-10-2004, 07:43 PM Is anyone having problems with brake rotors on their Dakota's from 2000-2003. I am on my 4th set ready for my 5th. They seem to warp very easily, any suggestions? Have you tried getting your tires balanced, i think if your wheels are not balanced it can cause your rotors to warp. wombat007 10-12-2004, 09:21 PM rotor warping is caused but excessive overheating and rapid cooling (driving through water) have you tried aftermarket rotors??? (Powerslot, Ebc or Brembo) get slotted not drilled. Dakota_Kacey 10-21-2004, 09:59 AM I am having problems with my rotors warping also. I've learned that since it's a heavy truck, it takes a lot to stop it. The overheating of the rotor is right, but I'm not sure about having the tires balanced. I have had my rotors rotated once and I need it again, all in the one year I've had mine. I guess I'm lucky, as you are on your 5th pair. How much are they costing you to replace? =) boats001 10-22-2004, 12:34 PM Hey try changing your rotors to an after market pair that are slotted. The origanil rotors warp because of heat Dakota_Kacey 10-25-2004, 09:53 AM To boats001, thanks for the tip, is there a certain brand that you recommend? =) vortmax 10-26-2004, 12:21 AM brembos or SSBC all the way. Also make sure the lugs are never over torqued. Any time someone other then you removes a wheel, losen the lugs and torque back to 100 to 120 ftlbs. That alone will save a lot of rotar probs Dakota_Kacey 11-04-2004, 08:50 AM How about Raybestos BruteStop or SuperStop? Are those any good? Their website recommends using semi-metalic pads, is that right? wombat007 11-04-2004, 01:22 PM Kacey, if you want the best (my opion) use the brembo sport slotted rotor and hawk HPS street brake pads, this combo is awsome!!!!! checkem out at tirerack.com and shop around. Dakota_Kacey 12-02-2004, 09:47 AM Okay, I have the new rotors and pads. When changing them, do I need to regrease and pack the bearings and what about a seal behind the spindal? Or does the Dakotas not need that? I can't find this info anywhere. Thanks for your guy's help! wafrederick 12-09-2004, 11:16 PM No,you do not.The wheel bearing is sealed and is not regreasable Automotive Network, Inc., Copyright ©2012
