Still won't start......
Juggalo
10-08-2004, 01:39 PM
Ok here's the story.. i took my 99gs into a shop like 2 months ago because on the way home one day my car just died.. i was shifting into 2nd and it just "shut off" so i had it towed to the shop.. they told me i had a bad crank sensor .. no biggie so i buy 1 and put it in because it was way cheaper for me to do it then for them to.. so it still won't start.. then they tell me my ecu is bad.. ok whatever so i go and get an ecu took it up there last week and it still won't spark!!! put a new cam sensor and new coil pack w/ new ngk plugs and wires in it and still won't start or even get any spark.. what else could it be? does anyone have any ideas? if you do please let me know i hate paying for a car that i can't drive!!! its been about 2 1/2 - 3 months since i have drove my car!!thanks for the input!!
~ Jim
EclipseRST
10-08-2004, 04:43 PM
did you check the fuses? check the wires running to the coil pack, check all the relays and all the ground wires running to the block to make sure its grounded good enough!
Juggalo
10-09-2004, 01:17 AM
i checked the ground wires as did the shop and they all are fine.. fuses are all good.. didn't check any relays tho.. maybe next week when i get back from the cruise
hellah fresh
10-09-2004, 03:15 AM
Relay aint going to help you man. I have a 96 Rs and I have the same exact problem as you. I replaced my ECU 3 time... New relays/ new starter/ coils/ cranks sensor/ oil pump/ battery/ cam sensor/ etc... still no spark. Its been 3 months in my shop we even tried to re-set the timing and its fine... so no clue man.... let me know if you find out whats wrong man =\
EclipseRST
10-09-2004, 08:38 AM
hellah fresh.... try switching your AC condensor wires with the coil pack wires (like the plugs) i have seen that happen a million times over... it even happened to me when i first built the RST! try it, seening you replaced everything and it still wont work i will bet its that!
hellah fresh
10-10-2004, 02:04 PM
AC condenser wires with the coil pack wire? ok... I can do that. Ill let you know what happend man. Its the 2 wires taht is by the clutch fluid right? when looking into the engine its on the upper back right side. got you
