G60 Conversion
01 GTi 1.8T
10-07-2004, 08:41 PM
This is a little bit too technical for me, so I need some professional advice.
I'm putting in a new clutch kit. Now, the kit I will be using requires a larger VR6 flywheel. I have been told it will fit right in with no modifications necessary, is this true? I need to know before I do the installation for they are covering the install labour under warrenty because they are replacing a leaking gasket at the same time. If it doesnt fit, I will end up having to pay upwards of $400 labour at a different time.
Does anyone know if the 1.8T can handle the VR6 flywheel with no modification?
Thanks in advance.
Refer to G60 conversion.
Dave
MidMazar
10-08-2004, 12:07 PM
http://forums.vwvortex.com/zerothread?id=764935&postid=11720726#11720726
I suggest searching, post it up on that forum and i'm pretty sure you will get a quick response!!
