Hello, as no one has helped with your question i thourght i would ask some more questions. Does your problem only happen in reverse? what are all the other gears like from cold? have you checked or changed your gear fluid? does the gear selector engage reverse and not drive, or does the lever not move into reverse?
If you could give us alittle more info on the car and of your complaint it may help.
Failing this have you tried to get a gearbox specialist to check the car, they will be able to give you the best diagnosis as they will be able to reproduce the fault.
nissantech
I live with fear all week, and at weekends SHE lets me go racing.
