VTEC vs CVTC
chris0276
10-06-2004, 02:29 PM
Hey Guys, which is better? Honda's VTEC or Nissan's CVTC? After using both, the CVTC feels more powerfull, but those Preludes and Integras are keeping up with the Spec V. I don't know much about engines. I hope you guys do. Thanks.
sr20de4evr
10-06-2004, 04:37 PM
They are completely different technologies that do completely different things, I don't know how you can begin to compare them. I mean that's like comparing a civic's shifter to a sentra's driver's side window.
chris0276
10-06-2004, 06:29 PM
Now I'm even more confused....LOL!!!!
sr20de4evr
10-06-2004, 09:01 PM
VTEC - the car essentially has 2 cam profiles. The lower profile is tuned for gas mileage and driveability, when the rpm gets high enough, the engine switches over to a more aggressive cam for extra power
CVTC - stands for continuously variable timing control. The ECU adjusts the engine's timing continuously to prevent detonation/pinging and optimize gas mileage. There is no crossover point, there is no 2nd cam profile, there is no extra power generated (actually there might be, depending on the specifics, but that's not what CVTC is there for, and it's only 1-2hp at most)
j scam
10-08-2004, 05:52 PM
cvtc wins at 5000 rpm the secondary lobes open up on the qr25de motor and it sounds like a vtec and boost a lil more. but you have to have a cai to hear it. vtec hits at 5300rpm and there's no comparison. the 2.5 with the right tuning and a turbo can spank almost any car on the street. i just sold my 00 civic si even with all the mods it still couldn't keep up with an ser spec v honda's don't have torque case closed
sr20de4evr
10-08-2004, 09:16 PM
what is it with you? do some research, you don't know what cvtc is, you don't know what the intake runners are, you don't know what happens at 5k, you don't know anything about how these engines work, and you don't know anything about the potential of the qr25 vs the potential of any other car out there.
TeggyLS
10-08-2004, 10:21 PM
Yep its the intake runners, that smooth out the power band, it switches in high and low rpm to give better low/top end power. but thats not CVTC
j scam
10-09-2004, 03:27 PM
i'm just learning about the cvtc so if i have the wrong info. why don't you say hey buddy look here it doesn't work that way it works this way and here's why etc. i don't get that i get guy's like you that suck d**k for a living. And try to flame ppl that are here to learn i am here to learn more about the qr25de. But guys like you suck so i can't expect respect from a d**k sucker. if you were a respectful person and you have knowledge to share. if you have the know how or knowledge then turn ppl on with quailty info when they have the wrong info about something. But once again since i had the facts about the secondary lobes wrong. Instead of geting set str8 with the 411. i get you some two bit sucker. had you responded respectfully you would have my att: and i might had even looked up to you and asked for more knowledge that you my have. But now i know that your a punk and don't treat ppl with respect. so f**k you
94tegRS
10-09-2004, 03:32 PM
because you come off as some kid that knows everything and just throws out facts like hey, this is how it is, I know all...
and you really have no clue.
j scam
10-09-2004, 03:40 PM
look i learned a lesson don't repeat what someone else tells you unless you can prove it. so qouted what i heard on another board and the info was incorrect. so i get flemed by some disrecpectful punk f that.
TeggyLS
10-09-2004, 03:56 PM
For someone who goes around calling helpful and respected members d**k suckers, id say your the little punk.
Now with a little searchin i have found this.
Variable-Valve Timing: "Nissan's Continuously Variable Timing Control (CVTC) electronically measures throttle position, vehicle speed and engine rpm, then adjusts the moment each valve breathes in. And it does this throughout the power band - from that first boost off the line to when you approach redline. Response time and efficiency are optimized. Power and torque, too." - Nissanusa.com
What does it mean?: Variable valve timing allows the SE-R's engine to get as much air as it can when you want it to. This adaptability enables the QR25DE to breathe very well no matter what engine speed it happens to be at. This technology gives the engine the most possible torque and horsepower from 1,000 to 6,200 RPM without the use of a turbocharger.
Variable Intake Timing: "More advanced breathing techniques, courtesy of Nissan. This one boosts torque in the low- and mid-rpm ranges, while tapping into the engine's full potential when it revs higher. At those higher rpm, it opens a secondary (and shorter) airflow path in the manifold, putting instant 'go' at your command." - Nissanusa.com
What does it mean?: When the engine reaches 5,000 RPM a second air route is opened up. This gives the engine more air. More air means more power. More power means more fun!
Last paragraphs from http://www.specplace.com/Performance.html
Now the ctvc smooths out the power band and does add some power, but there is no kick. the slight kick u might mean is from the intake.
Basically there is a short and a long intake runner. In low Rpms, air comes through the long runner only, at about 4.5k Rpm, a valve opens and air comes through both the long and short runners. Giving more air flow for your high rpm power.
94tegRS
10-09-2004, 04:11 PM
I am just taking a guess here but wouldnt it only come through the short at high RPM and not bothe because wouldnt the turbulence of 2 different airflow paths cause some sort of problem. I thought on the GSR at least it switches over to the shorter runners not opens both because the shorter runners flow better at high air speeds because of less surface area or something.
also jscam- you are right, dont quote someone else, unless YOU know that information or know they are right. and if you werebnt sure, there might be a couple words you can lreave off your post sto make yourself not sound so cocky and get flamed. and they are "CASE CLOSED" that doesnt sound like the words of someone who questions if hes right or not. and then "the 2.5 with the right tuning and a turbo can spank almost any car on the street." might not wanna add those words as well without any proof as to why you think this, even though its not even close to accurate no matter how hard you would try and prove it.
TeggyLS
10-09-2004, 05:16 PM
Well im not sure but this media file from nissan shows both open
http://www.specplace.com/Performance.html then go and click this Links: Learn how variable intake timing works!
under the variable intake paragraph
Really you can make almost any car spank another with enough money. But im sorry a well tuned spec will not come close to a well tunes, Supra, Skyline, WRX among others. No use bench racing, but Those play forms can make big power easily, Even the 4 cylinder wrx is AWD, which gives it a decided advantage over the Spec. Yes a turbo on a spec V will let u spank many street cars, but not all.
j scam
10-09-2004, 08:38 PM
[QUOTE=TeggyLS]For someone who goes around calling helpful and respected members d**k suckers, id say your the little punk.
if you come disrespect 1st then there's no way i'm going to swallow thats what you do. i don't even know you- don't come at me with that bullsh*t. 94tegrs just gave me a great response set me str8 but did not call me names and i get the point. he's kewl. when i 1st posted sr20det responed to my post saying you don't know anything. flaming me up instead of helping me out and being respectful about. if you look my post i had the wrong facts but i didn't know any better. i never called anybody anything untill he flamed me. instead of being informative. he came at me. so teggy "ls" "licks and sucks" you came at me calling me a punk when i never said one word to you i was talking to sr20det so fu*k you too. i will say something and i know civilians don't care about what i'm going to say. i enlisted in the marine corp and just got out not to long ago i was in iraq big deal right. but i went out there made it back. i don't know much about the qr25de yet but i'm learning. And i know that no one would know that i was in the usmc unless i told them that i was in. but to come to this site and have the wrong info you guys act like this is war. i was there so fu*k you
TeggyLS
10-09-2004, 10:43 PM
im not american, and your service to your country really doesnt impress me, sorry. And im not gonna get into a little flame war, with someone as immature as you. Maybe if you would take a more respectful angle at things you would get a little more respect.
sr20de4evr
10-10-2004, 12:02 AM
ok, I'm going to set this straight from my perspective
I don't know you, I don't care about your, or anyone else's feelings. The only thing that I DO care about is keeping people who have no idea what they're talking about from spewing blatantly incorrect information. If you don't know that much about the qr25 that's fine, if you came here to learn about the engine, its potential, and how it stacks up against the competition that's fine, but if you don't know any of the background or facts behind ANYTHING you are saying and you open your mouth anyway that is NOT fine. Ever heard that saying, "better to keep your mouth shut and be thought of as an idiot than to open your mouth and remove all doubt"?
Come here, ask questions, learn, and I will have absolutely no problem at all with you. But instead you came here not knowing what you were talking about, going around saying this crap that's so unbelievably wrong that I don't even know where to begin on analyzing it, and then when I call you on it you call me a dick sucker.
And if there's a 2nd thing that pisses me off more than all others, it's when people throw out service in the military as an "I'm better than you" achievement. Congratulations, you did what anyone on the face of the planet could have done. Yes I'm thankful that you "did your part" for this country, but that does not automatically make you better than everyone else despite what you may think. Thinking that it does only makes you look like an even bigger asshole.
j scam
10-10-2004, 02:57 PM
see your the punk. you have no idea what they're talking about spewing blatantly incorrect information. suck this who are to make anything you anit sh*t. and another thing ppl who never went in. never care about ppl who did thats why you act so apassve about it your a sucker. go light up somebody else's dick. you can't get off mine.
j scam
10-10-2004, 02:59 PM
i'm think you might be gay. since you staying on my d*ck be carefull ppl we have plugger online.
94tegRS
10-10-2004, 03:01 PM
did you just say people who didnt go in never care about people who did? youmean the military right?
thats a damn stupid thing to say. maybe I didnt wanna leave my newborn at home while I go maybe die, or maybe I have somthing on my record where they didnt let me enlist, or...
I dont have a kid, and my misdemeanors setled so I can NOW ewnlist but couldnt a while ago, but just giving you examples. he was just saying it doesnt make you BETTER than anyone else. and if you are its not cuz they arent a vet.
sr20de4evr
10-10-2004, 03:12 PM
jesus fucking christ dude, it's called english....learn it
you must be a genius, I can't stand misinformation and ignorant assholes so I must be gay. I can't believe how quick you came to that resolution, you know me better than I know myself.
j scam
10-10-2004, 03:15 PM
"better to keep your mouth shut as an idiot then open your mouth and stay on my di*k"
damm you love sucking. thats what i'm talking about if you didn't go in the mili. then for whatever reason you did not is whatever. but see kuz you did not- you hate -either your rich or not and you hate untill you are. so stay off my di*k un less your a true di*k sucker and if that is the case. by al means be your self son.
sr20de4evr
10-10-2004, 06:32 PM
did you go to college?
no wait, scratch that, did you even graduate high school? Don't bother replying until you learn how to put together a coherent sentence, you just make yourself look retarded. I'm not going to bother replying to anything you say anymore unless you speak legibly. You're not worth mine, or anyone else's time.
94tegRS
10-11-2004, 03:02 PM
j sca,m i think your gay, you mention something about a guy sucking your di*k in every post and make EVERYTHING about that. grow up, I now do noyt believe you were in the military cuz you have to have a high school diploma or a GED and have to have passed an ASVAB, which isnt hard at all though especially if you went army.
another reason I dont believe you is I know people that have and all of them that had any kind of attitude like yours came home without it it makes you more mature, not less.
TeggyLS
10-11-2004, 04:44 PM
Ya, I noticed alot of people saying they went to Iraq on the internet. Mostly 10 year olds, that dont know what mature means.
But i think we should get on topic again, argueing with him is stupid. Hes just a little punk and i posted before.
94tegRS
10-12-2004, 05:34 AM
well, in my oppinion the CVTC sounds better because its constantly adjusting the timing and VTEC is not, but on DOHC engines is it on both cams or just one? I would rather listen to VTEC though because I LOVE that sound when it crosses over. now Ivtec vs. CVTC Ill give the Ivtec props cuz as far as I know it has a crossover p[oint as well as infintely adjustable intake cam timing.
TeggyLS
10-12-2004, 05:41 AM
ya, Honda Vtec motors sound pretty nice in the top revs, with the right exhaust that is, i hate those coffee can mufflers kids put on, sounds like a lawnmower.
But i like the size of the Qr25, once you get those internals taken care of, it loves to make big power with a turbo.
94tegRS
10-12-2004, 05:45 AM
yeah, I raced a civic that sounded HORRIBLE, like, me shaking my change tin. I was one of them for a while, you dont know your car sounds like total crap until you let someone drive by. I thought mine sounded decent but when I went to my friends muffler shop to get my exhaust done before I had him do anything I just had him rev it and man it sounded like hewas revving up a CR250 or something, wekll not reaklly but im sure you know what I mean,. so I had him throw on a glasspack at the end and a new tip and it quieted it WAY DOWN and got rid of thew 2 stroke rap.
jmrev
10-15-2004, 12:47 PM
VTEC has been around more than CVTC so i would say VTEC, Why i seen it work on almost all honda engines. But the SER puts out more torque
94tegRS
10-15-2004, 05:19 PM
about every manufacturer has more torque than honda tho.
Lychus
11-03-2004, 07:56 PM
all i know is that i got a stock 95 gsr and my boys got a 04 spec v with intake and exhaust and i owned him everytime. My vote goes to Vtec
chris0276
11-04-2004, 09:19 AM
All I can say is that your friend can't drive his 04 Spec V or your GS-R is not stock. He should be able to beat a GS-R without any mods on a Spec V. I know I have and mines is a stock 02 Spec V. The Spec V has a lot of torque and not many people know how to control that torque when taking off. I still think the CVTC engine is superior because it produces more power and torque at 6200 rpm than a VTEC does at 8000rpm.
Lychus
11-05-2004, 02:02 PM
actually hes a good driver and ive raced 3 spec Vs already and ive beaten them all. Maybe u havent raced a 95 gsr. they arent all the same. 95 and 99 have a better computer OBD1. His 04 beats my other friends 02. The newer ones seem faster. He hasnt lost to an older one yet
xtoyotacorex
11-15-2004, 04:55 PM
haha
