97 EX Idle ProblemBennyBakwood007 10-06-2004, 09:01 AM Yesterday out the blue, my car just cut off when i was going around an exit to get on the beltway, it wasnt in gear and the clutch was not engaged, but for some reason she just cut off on me. I started her back up with no problem but when i was sitting in traffic it happend again. For some reason she is idleing at about 500 RPM's when she usually idles at about 1000. After a minute or so of idleing at 500 the RPM's drop completely and she cuts out. I suspect its my injectors but when im accelerating theres no stalling or sputtering so im not really sure...less then 5 minutes before she started cutting out on me i filled the tank with a good quality gas so im pretty sure its not the gas, so right now im stuck. Any one out there have a clue whats goin on? Any and all feedback is appreciated. Silverbolt 10-08-2004, 06:34 AM How many miles do you have on your car. Do you do maintanance yourself, or bring it in? Is it throwing a check engine light? When it idles low, does it kinda sputter? It could be a number of things.. you might need a new PCV valve, or have Bad or low oil, faulty throttle body sensor aka "TB sensor", Intake element needs to be changed, spark plugs and/or wires... BennyBakwood007 10-08-2004, 08:28 AM well the car has about 111,000 miles and i do all the maintenence myself, i recently put a new OEM clutch and flywheel in, changed the timing belt, spark plugs and wires and more recently then that installed a CAI. All the fuel injectors have been thoroughly cleaned within the last 6 months. I only have that problem when i am sitting in traffic, every now and then the RPMs will drop from 500 to 0 and the car will cut off...she starts up again with no problem, but now im starting to notice a short sputter when i am in, lets say 3rd gear and driving at about 15-20 mph...that never happened before so im not really sure whats goin on.... Silverbolt 10-08-2004, 03:11 PM Have you changed your PCV valve recently? Try swapping your spark plug wires back to stock and test drive it. The only thing I can think of is that your PCV valve needs to be changed. BennyBakwood007 10-08-2004, 05:38 PM Thanks...Im gonna check the PCV Valve this weekend..as for the spark plug wires, there OEM, the last set i had were performance and there was no noticable difference other than the $$..actually my throttle responce is a lil better since i put the OEM set in...go figure...but thanks for the feedback, its much appreciated Silverbolt 10-08-2004, 10:03 PM You're very welcome... hope I was helpful. Keep me updated on the problem. BennyBakwood007 10-25-2004, 08:47 AM Finally got the PCV Valve changed and now she runs good as new...thanks for the help it is really appreciated. Automotive Network, Inc., Copyright ©2012
