OBD II 96 ranger P0320sandmantoy 02-15-2002, 04:03 PM Hey Guy's Friends truck is stuck in my driveway. 96 ford ranger 2.3 4cyl. w/8 spark plugs. starts and runs but has fits of misses. if you bring the rpm up slow it will not miss. If you try to drive it looks like granma's first time drivin a standard. OK so i got a diagnostic tool it reads and erases only. I got a code P0320 ign/dist engine speed circut malfunction. the engine has no distibutor can't find a ign module even. I did put plugs,wires and fuel filter and cleaned up battery termanals. Checked the grounds checked connectors and replaced the crank sensor just in case. I was an ASE mechanic in the paper clip days but this one has got me. Has any body seen this one before or can tell me what I should do next? things I suspect are the coil/coils pcm or fords famous wireing! truck has 60,000 miles on it and nothing has ever been replaced or repaired until now. so I ruled out something being left off or installed poorly. Think I have checked all the wireing and am at a loss. ......sandman....... Stevo2 02-22-2002, 05:41 AM Just found this forum. I'm not totally sure about your ignition system but when I did a search on the web I came up with an ignition module that looks like this...http://www.partsamerica.com/product_images/AAP/GPS/EL144.jpg maybe there is a bad connection there our an intermittent module. Regards-Stevo:) Chriss 10-11-2003, 07:56 PM I got this code on my ranger and no clue where to start, Anybody got some good lead here. Thanks Chris Automotive Network, Inc., Copyright ©2012
