How to turn up boostLuke18 10-06-2004, 12:11 AM I have a GSR stock with a turbo set up. My boost level is set to 7 PSI. I was reading other threads that stated stock internals can handle up to 9 PSI. I want increase the boost level to 9 PSI, what do I need to do? chixSI 10-06-2004, 02:02 PM What you need to do is get a boost controller and then you need to get your car re-tunned. DeleriouS 10-06-2004, 04:17 PM it depends on what your setup is...do you have an internal wastegate or external. all you need to do is get a manual boost controller and you can tune your boost level. you have a boost gauge...right? civickiller 10-06-2004, 04:38 PM stop thinking of psi number as to what the stock internals can handle. a stock gsr block and handle 300whp reliable. now you want to turn up the boost, is your car tuned for it ? what management are you using ? like chix said but i would get the car tuned first before the boost controller because if you get the bc first you might be tempted to turn up the boost before you tune it, or install it at the same time Luke18 10-06-2004, 06:22 PM I have a External Wastegate and I do have a gauge. I am using the Vortech FMU. I was thinking of getting the Apex AVC-R or are there better ones? scottsee 10-06-2004, 07:15 PM avc-r is preatty expensive, its defently a great boost controller! no doubt about it. its major feature is the rpm staged boost. great for traction off the line with fwd. my personal favoret is profec-b. for the $ its all most people need. i run a manual boost controller with a bleedoff nut. it was $20, you can make them from "home depot" for $3-5. if you want to spend the $ for a boost controller go ahead. or you can invest that extra $ somwhere else. b164gturbosi 02-03-2005, 11:43 PM bleed off nut?what do u mean TypeGsR 02-18-2005, 11:48 AM boost it 30 pounds...lol boosted331 02-18-2005, 01:10 PM Instead of wasting 400+ bucks on an AVCR, run hondata/uberdata + bigger injectors and a fuel pump. I wouldn't push past 7 psi on a silly FMU setup. superbluecivicsi 02-18-2005, 11:39 PM or you can push past 9 psi and give us your results afterwards ;) let us know how far you get. Automotive Network, Inc., Copyright ©2012
