Oxigen SensorsrodeoFLA 10-05-2004, 03:38 PM I already change the oxigen sensors on my rodeo 2000 3.2L, I did that due to error codes P0171 and P0174, But the problem remain the same. What else i can do to fix it? 2eyefishclaw 10-05-2004, 09:20 PM intake gasket leak will cause these codes also rodeo02 10-06-2004, 01:05 PM Usually the ONLY time you want to change out O2 sensors, is if you have a slow or no activity code from them, or if you have tons of miles on them (like 120K+ miles). Like 2eye says, you probably have an intake manifold gasket leak which throws off the fuel trim, causing the lean codes. G/luck Joel rodeoFLA 10-11-2004, 04:09 PM intake gasket leak will cause these codes also Thanks guys, I'll check the intake gasket Automotive Network, Inc., Copyright ©2012
