i have a 94 beretta which also had idle misfire problems. i replaced the spark plugs and wires and that seemed to help a little bit. also, try adding a bottle of fuel injector cleaner to the gas tank every once in a while. a little after this, the check engine light came on with an improper idle code. I had the IAC valve replaced about 6 months ago and its been running fine since with no idle problems what so ever.
