help with switchesesp 02-15-2002, 10:12 AM does anyone know how to wire like for example fogs lights or anything else up to a switch? do i go wire the switch to the battery and then what ever i need to power wire that to the switch. do i ground the switch or just go back to the negative terminal on the battery? i know that the switches that are required are 12 volt right? any help will be greatly apprieciated supafly1024 02-15-2002, 10:32 AM You'll have a wire coming from your battery or power source, then a wire running to whatever your powering and you'll have a ground wire, which is not hooked up to the negative battery terminal by the way. markpa 02-15-2002, 05:41 PM you can run it directly to the batter ground. Phat804lude 04-01-2002, 06:43 AM Actually, there are some switches out there that you don't have to ground. 2 of the toggle switches that I have in my car are not grounded and they work fine. But, if there is a ground switch, you can hook it up to any bolt that is connected to a good deal of metal and if it's painted, make sure you scrape the paint off. Automotive Network, Inc., Copyright ©2012
