Whining Sound 98 Rodeo
megavolt121
10-04-2004, 09:04 PM
I just got my 98 Rodeo LS 4x4 5spd.
Whenever I rev up to around 3500rpms, i'll hear a whining sound. Any clues what this is from? When I leave it in neutral, I wont get the sound. This sound really concerns me. I had to drive from Los Angeles to Santa Cruz, all w/ this sound. I avged 170 miles/12 gal or 14mpg. I'm one of those fortunate ones to have a fual guage that isn't accurate either.
I also pushed the 4x4 button and the thing shifted into 4wd, but when I tried to disengage it, the indicator light flashed and wouldn't disengage. Finally after driving 4-5 miles to dinner, I made a u-turn and it disengaged. Is this normal?
amigo-2k
10-04-2004, 11:34 PM
your 4x4 maybe engaged (I'm not sure on how to check if it is).
You could have a bad intake manafold gasket.
couple Ideas on lower MPG:
http://www.geocities.com/endre_rl/isuzufaq.htm#faq8
megavolt121
10-05-2004, 02:54 AM
I'm not sure if its the 4WD or not. I'm inclined to say it isn't since there's still plentyof power to go fast, and I can turn easily.
What's a good way to tell if its a bad Intake manifold gasket? I had my engine compression checked by a AAA mechanic. Out of 180 points(or whatever it means), i scored a 175 or so.
amigo-2k
10-05-2004, 09:40 AM
http://www.geocities.com/endre_rl/isuzufaq.htm#faq5
iskiuskiweski
10-05-2004, 04:22 PM
I don't know about the whining, but the 4WD thing is normal, I also have a 98 and the same thing occurs when I go to 4WD, I have to make a couple of tight turns to get it to completely disengage. But I make the turns and it disengages and stops blinking. Not sure why this happens I have just come to expect it. Someone also suggested checking your tire diameter to ensure they are all the same, as I have learned this is very import with these 4WD systems.
2eyefishclaw
10-05-2004, 09:19 PM
guys to disengage 4x4 you need to put the vehicle in reverse and back up about ten to twelve feet continue what you are doing and it will cost a lot of money later on
megavolt121
10-07-2004, 01:34 PM
Ok so if i don't fix this gasket soo, will it have any long term effects?
iskiuskiweski
10-08-2004, 01:41 PM
Please explain, I thought these were supposed to be shift on the fly systems. I didn't think it was like with manual hubs that you had to backup in order to disengage it.
rodeo02
10-08-2004, 01:55 PM
You have to back up to disengage auto locking hubs (up to 1997). No need to back up with the drive flange setup on 1998+
Joel
iskiuskiweski
10-08-2004, 02:39 PM
Thanks. That is what I thought. Both of the Rodeos discussed in this thread are 98's. I was worried there for a minute.
