Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 10-04-2004, 10:41 AM   #1
flash12
flash12 Normal reputation
Angry Trouble with 99 Silverado 2500 6.0L cutting out while towing
I am having trouble with my 99 2500 Silverado 6.0L wanting to "Cut out" and sputter while towing, especially up hills when under a load. If you back out of the throttle if will not do it as bad but then of course you lose power and end up at 35-40 mph at the top of the hill. Has anybody else had any trouble like this where you can tell me what to look for. Thanks!
flash12 is offline   Reply With Quote
Old 10-04-2004, 01:12 PM   #2
Puffnstuff
Puffnstuff's Avatar
Puffnstuff
Send a message via ICQ to Puffnstuff
Re: Trouble with 99 Silverado 2500 6.0L cutting out while towing
Have you checked your fuel filter?
06 Toyota Tundra Double Cab
Puffnstuff is offline   Reply With Quote
Old 10-04-2004, 01:14 PM   #3
flash12
No I haven't. I was thinking of that but thought that was probably to simple. I will check it out. Where is the fuel filter located at on this truck?
Old 10-05-2004, 08:06 AM   #4
Puffnstuff
Puffnstuff's Avatar
Puffnstuff
It's on the frame rail.If you do change it out make sure to put a rag underneath it so the gas doesn't eat the protective wax off the frame I used to pull the fuse to the pump and let the engine run until it died to relieve pressure on the line before I opened it up to remove the filter.
Bookmarks
Google
Web AF
