Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > RAV4
Old 09-30-2004, 03:46 PM   #1
JonRav4
JonRav4 Normal reputation
Question Cold idle failing, sometimes
Hi All,
Our '96 Rav4 is having an intermittent problem with the cold idle. Sometimes it fails to keep the rpms up and will stall unless I keep the peddle down. Doesn't happen every time; about 1 in 4 starts. Only lasts for a brief period. Seems to idle ok after a minute or so. Runs fine when warm. Any ideas?
Thanks,
Jon
JonRav4 is offline   Reply With Quote
Old 12-09-2004, 04:23 PM   #2
tsmith3108
tsmith3108 Normal reputation
Rav4 idling problem
A friend has a Rav4 that is exibiting the same symptoms. Did you ever get yours fixed. Was it the idle air sensor??
tsmith3108 is offline   Reply With Quote
Old 01-02-2005, 10:49 AM   #3
rcamarero45
rcamarero45 Normal reputation
Rav4 cold stalling
Im having the same problem with my 2000.
Did you ever resolve it?
A friend of my suggested using a fuel injector additive.
Thanks
rcamarero45 is offline   Reply With Quote
Old 01-03-2005, 04:34 PM   #4
tsmith3108
Re: Cold idle failing, sometimes
Dealer was unable to recreate or verify cause of problem at all as it does not post codes in computer. I replaced the fuel filter and cleaned the maf while troubleshooting. Fuel filter was quite dirty and may have been the cause but thats the best I have. It seems to be fixed but I cannot say exactly what fixed it. Been going almost a month in the cold with no symptoms though. Worth a try and the fuel filter could probably do with a change if you have more than 40K on it anyway.
Old 08-01-2005, 03:40 PM   #5
jm102399
jm102399 Normal reputation
Red face
I just went through this it's the idle speed control valve, check to see it's not dirty if it is clean it. The only problem is once you do that you might have to replace an IAT sensor or coolant sensor. Not expensive
Best of luck
jm102399 is offline   Reply With Quote
Bookmarks
Google
Web AF
