Trottle
Google
Web AF
lonelybull
06-02-2001, 03:48 PM
I just bought a 1991 G20 and it is not idling properly. I put a fuel injector cleaner in and that didn't seem to work. What els can i check for or adjust? Thanks
DVSNCYNIKL
06-02-2001, 05:59 PM
Try adjusting the timing. You might want to check your plugs also.
enzo@af
06-03-2001, 01:46 AM
He's right...plugs/ wires, maybe distributor...
Otherwise, timing sounds like the problem.
ales
06-03-2001, 03:39 AM
As well as O2 sensor...
Good luck
poppy_morenito
06-03-2001, 08:02 AM
If you just bought it used. Look inside oil cap and make sure you car is not all sludged up on the inside. I am learning this lesson the hard way now ... if it is take it back !!!
I had idle problems that turned to hesitation problems. I found out my engine's cam and rockers are all groung down..... Now I need new engine because the insdie of my enigne looks like the grinch's heart or irs agent....
Google
Web AF
