clunking noise in front suspension
plasticlizard
09-28-2004, 01:08 PM
I'd like to know if anyone has information related to TSB 01-03-08-002B APR 03 Suspension - Front Suspension Clunk/Rattle Noise
My Mom's Malibu has such a noise. I'm looking to see what the TSB says the noise is.
If you know please post the cause and the solution here.
Thanks so much.
ViperJ
09-28-2004, 04:28 PM
This might be the same problem, http://www.automotiveforums.com/vbulletin/showthread.php?t=281184
plasticlizard
09-28-2004, 05:12 PM
I'm not sure it's the same problem. But if there is a TSB then it has been identified as a common problem. That's why I want to know what this particular TSB says.
LowPost42
09-29-2004, 12:07 PM
When is the clunking making noise? It might be a CV Joint.
plasticlizard
09-29-2004, 01:48 PM
it's happening mostly at lower speeds. It sounds like something loose in the glove box, but it's really coming from the engine area. I think it's a CV or some suspension component.
That's why I want someone with the Alldata file to post the TSB here.
Johnny R
09-30-2004, 11:12 AM
I hope your clunk is not as bad as mine was. The coil spring had broken in two, and every time I turned the steering wheel the two pieces sproinged.
bowtie4ever1986
11-06-2004, 09:15 PM
well it might not be the same as mine but my 01 did the same when i hit a bump or pot hole mine was my brake pedal moving try putting youre foot on the sibe of the brake pedal and se if that makes a diff hope it does
