Parts for my 360whp gsr... suggestions?
teggieboost
09-28-2004, 03:47 AM
These are the parts I am planning on getting: will u give me a quote for these parts for my Acura Integra GSR? It is running a PT67 turbo and making 360whp at 12psi on pump gas. Let me know if these are good parts and if you have any other suggestions or alternatives...
1. Semen 83 (83 lbs injectors) - are these the best idea for the race gas at 18 psi?
2. quaife LSD w/brass & bearing
3. nossport sport compact kit, purge kit, bottle heater, & bottle
4. slicks - m&h24.5, 13x8 rims
mellowboy
09-28-2004, 04:50 AM
LSD is always good to have! Slicks ...of course! I'm not too sure about run'n pump gas on those type of injectors. I think it'll be too much.
What compression are you running?
tsugsr
09-28-2004, 11:51 AM
so are you selling it or keeping it? and go for the slicks and LSD. and for 18 psi and stock compression ( if thats the case) I think those injectors would be overkill, and I doubt you wanna drive around with just race gas and horrible milage, imo. Id deffinitly say no to the Nitrous unless your intire engine is completly BUILT, and i mean everything reworked, even then nitrous wouldnt be nessicary, just up the boost and maybe put a nitrous cooling spray infront of the intercooler.
teggieboost
10-03-2004, 06:57 AM
the nos is only to spool the turbo faster, like a 35 shot. the engine is completely built with 8.5:1 compression. Turbo reaches full boost from 6-9k rpm
