Lug pattern/backspacing for '00 PreRunner?lifetrddeath 09-27-2004, 10:49 AM What is it? I've seen this number float around, 6x139.7. Is that correct? lifetrddeath 09-27-2004, 09:13 PM Please guys. Okay, The 6x139.7 i found to be correct. But do the 2wd and 4wd have different center bore? I know the 2wd is 3.25” (82mm), anyone know if the 4wd is different? lifetrddeath 09-27-2004, 09:15 PM And on top of that, if the center bore is different on the 2wd and 4wd, which would the PreRunner have? Being a 2wd with a 4wd setup. SEAN_at_TLT 09-27-2004, 11:36 PM Pre-runner is the same as 4wd in every dimension. It is a 6-lug, 5.5" BCD pattern with 4.5" offset. I don't know the center bore (for hub-centric?) but most aftermarket wheels are lug-centric anyway. I am sure it (4x4/pre-runner) is larger than the 2wd "mini" 5-lug though. Hope that helps. lifetrddeath 09-28-2004, 10:29 AM It does help, thanks. And yes, it involves being hubcentric with wheel spacers. I need to know if one will fit and the center bore kinda matters. SEAN_at_TLT 09-28-2004, 01:40 PM Ahh, wheel spacers. The center-bore is 4.25" (108mm). All 6-on-5.5" BCD rims should be the same (chevy, Toyota, etc). Do you already have the wheel spacers? If not WFO Concepts (http://www.wfoconcepts.com) will custom make any spec wheel spacer to suit your needs. lifetrddeath 09-28-2004, 02:05 PM Again, lots of help, thanks. I'm getting my tires and wheels next week, 35" M/T Radial Claws on M/T Classic II wheels. I just wanted to push my stance out a little, at least 1 1/2" ya know to fill in the TRD fender flares. Thanks again! SEAN_at_TLT 09-28-2004, 03:34 PM Are you going to push it out with more backspacing or wheel spacers? lifetrddeath 09-28-2004, 04:52 PM The wheel spacers. Automotive Network, Inc., Copyright ©2012
