what do all those #'s mean?
Adam
06-01-2001, 04:50 PM
so..
YogsVR4
06-01-2001, 04:51 PM
I must be missing something. What numbers?
Adam
06-01-2001, 05:57 PM
I sure hope you're missing something because If your not, I am..
umm... things like 255/35ZR-18??
DVSNCYNIKL
06-01-2001, 06:13 PM
The first number has to do with the width of the tire. From the outside to inside.
The second number, has to do with tire profile meaning from the edge of the rim to the outside part of the tire.
The letters are the speed rating of the tire.
The final number is the size of the rim it fits.
Adam
06-02-2001, 03:40 PM
i see isee
CraigFL
06-02-2001, 07:09 PM
255/35ZR-18
To be a little more specific:
255 = Width of tire in millimeters
35 = aspect ratio in percent (35% means the height of the tire is 35% of its width. In this case 35% of 255mm = 89mm
Z = speed rating , in this case 149mph
R = Radial Ply tire
18 = rim diameter in inches
Don't ask why some is in mm and some in inches...
flylwsi
08-04-2001, 03:48 PM
it is explained really well on www.discounttiredirect.com
and, on the aspect ratio, i believe it is the distance from the rim to the ground, not including the bead... but go to the site, and they give you all the technical shiet...
Chris
08-27-2001, 11:46 PM
Man, its in inches and millimeters to Confuse you!!
more speed ratings:
Q=99mph
S=112mph
H=130mph
Y=189mph
Z=149mph+
There are more, I may poste them later.
Most tires are S rated. (family cars anyway)
