1991 Cutless Cierra SL -all power windows fail!bikerwolf 09-25-2004, 02:51 PM Hello Everyone, Anyone out there with the mechanical/electrical expertise to suggest where I should go to get this problem resolved? None of the power windows are working...currently some are up others are all the way down. I would greatly appreciate any guidance at this time. I just want to know if it's going to be a pricey fix and what should I expect when they do tell me what is causing the failure. Thank you for your time and effort regarding my car troubles. richtazz 09-25-2004, 03:47 PM try the simplest thing first, is the fuse ok? next, I would check the drivers door switch. Power to all the other switches route through the drivers switch. bikerwolf 09-26-2004, 09:44 PM try the simplest thing first, is the fuse ok? next, I would check the drivers door switch. Power to all the other switches route through the drivers switch. Hey Rich, Just wanted to extend my thanx and to let you know they are all up and working again. I reconnected the circuit breaker in the fuse box for the power windows and then just tweaked the driver's switch...voila! Bikerwolf Automotive Network, Inc., Copyright ©2012
