Socket Sizes and procedure for Wheel Speed Sensoroutrag1 09-24-2004, 05:40 PM Hello, Vehicle in question is: 1999 Chev Tahoe 2Dr 4X4 I'm looking to replace the wheel speed sensor in the left front assy. I've taken the tire, caliper, and rotor off the vehicle at this point. Can someone provide the socket size for the axle nut (34mm - 36mm maybe?) and also the 3 bolts holding the hub assy to the knuckle (15mm maybe?). It would also be appreciated if I could get the procedure to replace just the wheel sensor. In other words, do I need to remove the axle nut and the hub bolts and the assy from the car? Can I just try and remove the two hub bolts holding the shield in place to get at the sensor? Thanks - Bob Automotive Network, Inc., Copyright ©2012
