cel codes my car is shot i thinkwhatsgood 09-23-2004, 10:59 PM ok well i know i posted a few threads before but now i know what all the problems are .. to start off with ive got a 95 5 spd civic coupe wit 1.6L vtec .. my cel has been on so i found out that i could check the codes from my ecu and i came up with a sh1t load of codes .. code 14 =idle air control valve , 17 =vss -speed sensor , 19 =automatic transmission lockup control valve , 21 =vtec spool solenoid valve , 22 vtec pressure valve..... please help me out with what these parts are and where they are located thanks ( exept for the iac i know where that is ).... 97CivicX 09-23-2004, 11:01 PM if your oil is low that could be the vtec codes CivicSpoon 09-23-2004, 11:23 PM Ummm... I'm doubting you're throwing a "automatic transmission lockup control valve" code with a 5 speed; unless of course you did an auto to manual conversion. Automotive Network, Inc., Copyright ©2012
