85 Corolla Strange SymptomsFitchman 09-23-2004, 02:14 PM I'm not certain if this is a fuel pump/fuel filter issue, or a electrical/starter issue. Here's the history... I have a 45 mile one way commute daily... I've had problems with my Corolla hesitating when the engine is cold, like at a stop light. When trying to go into 2nd gear it runs rough, and has stalled. I mentioned the engine being cold, because I didn't have this problem when leaving work. Once or twice at highway speed, I've had a serious hesitation, like it was going to stall... fuel filter right? This only happened once or twice. I figured bad gas... More recently, the car wouldn't start at all. I went to start it, and it turned over three times, then just a click. That's it. I figured.. bad starter. Three days later, I went to test it again, and it started up with no problems. :screwy: Perhaps I have multiple problems... the starter may be going out? The fuel filter probably need replacing...? I don't know where the fuel filter is. I'm sure it's outside the fuel tank... Fitchman 09-25-2004, 11:05 AM I replaced the fuel filter this morning. I'd been about a year. The car is taking a while to engage. I wonder if the choke needs adjusting. I've determined the starter is fine. Every time, except one, the engine has cranked over just fine, just slow to engage... Automotive Network, Inc., Copyright ©2012
