Valve Removal + EGR = SMASHKILLDESTROY!Grenyaer 09-22-2004, 10:34 PM I'm trying to remove the valves on my KA and it's being a bitch. The fsm says "Remove valve components with Tool." and refers to the fancy valve remover tool that I of course don't have. From what I can see, I need to compress the spring to remove the cotter. Is there an easy way to do this that anyone has done? It's giving me a hell of a time. Then on top of that, that huge god damn nut holding the EGR into the exhaust mani is being a stupid bitch too and I think im gonna need a torch to get it off. So everything is at a stand still because I suck and don't have enough tools. Sorry I'm venting. I get my SR in 5 days...so I just been playing with my KA taking it apart. So I am always reluctant to buy special tools just for stupid shit like one nut on the EGR tube that I should just break off anyway. But since you guys are all geniuses im sure SOMEBODY has some crazy maguyver way to get this shit off right! thanks yall! TatII 09-23-2004, 01:11 AM the nut on the EGR needs to be torched. no matter what kind of wrench you have, that 10+ year old nut is not gonna come out. J SPEC SilEighty 09-23-2004, 01:26 AM Yep, I took a torch to mine when I removed the EGR. I tried a huge adjustable wrench on it, which by the way barely fit the nut when it was maxed out, and I couldn't even budge the fucker.... so I just torched the bitch off. ghostchild316 09-23-2004, 01:45 AM you guys suck as mechanics.are you using the right size?try 15/16 next time J SPEC SilEighty 09-23-2004, 01:59 AM lol I couldn't move it at all. Once I finally got the wrench on there I just couldn't even begin to turn it. maybe i'm just to weak :( vsiev 09-23-2004, 03:32 AM I think the tube was more like a 19, but it turned easy for me when i changed out my exhaust for my hotshot header. SR20DETpower 09-23-2004, 05:37 AM use a healthy dose of wd-40, and then stick a tube on the end of your tool for more leverage........ heat is the enemy on an engine wd-40 is a mechanic's friend nissanfanatic 09-23-2004, 03:33 PM Why would it be a 15/16? Every nut or bolt I have taken off of the car has been metric. Whatever works though. I'm not saying your wrong. But anyways, you can try some Kano-Kroil. That is some good stuff. It came out pretty easy for me w/kroil. The bitch was getting it back in. Now I remember how much I hate EGR. Good luck. grncivicdhr 09-23-2004, 06:33 PM definatly can't go wrong with kroil. i use that in shop at school. it always works. Grenyaer 09-23-2004, 09:29 PM I've tried them all and the nut started stripping, so I'll torch it I guess. What about the valves? Is there an easy way to get them out? nissanfanatic 09-24-2004, 08:16 PM One more thing you could try is a big set of robogrips from Craftsman. Those have saved me on a couple bolts. Either that or a pipe wrench. Good luck. Automotive Network, Inc., Copyright ©2012
