having problemschplynne2000 09-22-2004, 09:27 PM no signals or hazard lights working, fuses are good, any ideas? pind 09-24-2004, 11:03 PM try replacing the flasher unit. If all signal and hazard lights are not working, this is the most likely culprit chplynne2000 09-25-2004, 02:26 PM try replacing the flasher unit. If all signal and hazard lights are not working, this is the most likely culprit do you have any idea were this is located, I have looked everywhere and can't locate it. I did purchase the flasher unit, but no one can find it. thanks alot, this has saved alot of time pind 09-25-2004, 10:42 PM The flasher relay for your Tacoma is located on junction block #1, behind dash, left of steering column. Fuses for the hazards and turn signals are also located on junction block #1. chplynne2000 09-27-2004, 08:16 PM The flasher relay for your Tacoma is located on junction block #1, behind dash, left of steering column. Fuses for the hazards and turn signals are also located on junction block #1. thanks for all your help, but it is not the flasher, I did change it but nothing. Can it possibly be the relay? thanks again Automotive Network, Inc., Copyright ©2012
