Whats JDM?
99SilverG20t
02-12-2002, 04:51 PM
What is the major difference between the jdm b16 sir2 and the b16 found it the 99 civic Si? Thanks
Swonder67
02-12-2002, 05:24 PM
prolly some emissions stuff. JDM=Japanese Domestic market.
bluecoma
02-12-2002, 05:56 PM
I know the JDM b16 is a DOHC i'm not sure about the USDM b16 in the civic si, i think it's a SOHC, not absolutly sure. That may be the difference.
Rice-Rocketeer
02-12-2002, 06:19 PM
The major difference is the upgrade from OBD 1 to OBD 2.
Folks, if you don't know, don't answer. It's very simple.
kidrocket
02-12-2002, 07:11 PM
usdm b16 is dohc vtec
SRHguru
02-12-2002, 08:02 PM
That would be a DOHC, just like the rest of the B series.
VTEC_boi
02-12-2002, 08:29 PM
muahahahahahahahahahaha!!!
THANK YOU FINALLY SOMEONE SAID IT :D
B16As are found in OBDI and OBDII Civic SiRIIs. The advantage is the JDM one has about 168-170hp whereas the USDM version packs 160hp.
peace
boi
CivSiGuy
02-12-2002, 09:50 PM
You also have to take into account that JDM motors are running on higher compression because of the higher octane fuel used in Japan. That is a big reason behind the hp increase.
99SilverG20t
02-13-2002, 03:18 AM
I'm thinking about just buying the motor alone if the usdm tranny will work. I figure that may save a few bucks. If you can use a usdm tranny which ones will work? Is the electrical system different on the jdm vs usdm? The seller i'm talking to is giving me an option of the obd1 or obd2 ecu. Which do you reccomend I get and how can you tell the difference by looking at it. What else will i need to do a complete swap. I know that the motor mounts will work fine. Will I just need the axles if i'm getting the jdm sir II motor and tranny? Thanks for all your help and i'd appreciate it if either VTEC_boi, Rice-Rocketeer, or anyone who can really help answer the questions.
Yo vtec_boi, i like you signature. Its hilarious!
99SilverG20t
02-13-2002, 04:17 AM
Is this another ecu for the b16? Thanks
sparq
02-13-2002, 05:06 AM
PWO, PR3, and P30 are all differant B16 ECU's ... the one you need will depend on the car you have. Which car will you be swapping into? Anything 96+ you will want to go with OBD2
Rice-Rocketeer
02-13-2002, 12:49 PM
Any b-series tranny will work but the B16 and B18C1 trannies are reccomended for the gearing.
If they are the same OBD...no. They might have slight differences to your car which will be addressed with the swap.
I reccomend staying with the same OBD system your car originally came with to keep it legal. 5th gens had OBD1 and 6th gens had OBD2.
This will tell you almost everything: http://www.automotiveforums.com/vbulletin/showthread.php?postid=189840&t=5861
You will need the axles from an LS, if I remember correctly. But don't quote me on that, you need to research.
It should be, I gave it to him :D
VTEC_boi
02-13-2002, 06:06 PM
Yep...RR gave me the quote as a birthday present :D muahahaha
Anyways...
Just order your motor through Sparq - he sells JDM B16As and can point you in the right direction.
If you need to know anything else just hit me up on here or AIM: Thevtecboi
or...(shameless plug) for JDM civic info and fun www.jdmcivic.com
I'm a moderator there :D
