5.2 Ignition timming
rgrenier
09-21-2004, 11:57 PM
Can you set the timming for a 98 dakota 5.2 liter? If so how? If not what did I do when I moved the distribtor? The truck runs put pings at 3500 rpm or so. Now I just want it to run better. It also uses oil, it only has 76000 miles on it.
Russ
mprtech
09-22-2004, 10:29 AM
It needs the intake manifold gaskets replaced, and the pcm reprogrammed.
rgrenier
09-22-2004, 12:43 PM
So you can't set the base timming like older GM stuff by disconecting a wire or something like that?
Is any of this a recall? Is the intake the oil consumtion?
Thanks for your help.
mprtech
09-23-2004, 05:07 PM
Nope, no recall just a pretty common problem
rgrenier
10-05-2004, 12:03 AM
Thanks for the help.
