Piston slap in C6???C_Dogg 09-21-2004, 03:49 PM Well I wonder if the new C6 will inherit the infamous piston slap from it's predecessor??? Hopefully GM has learned a lesson from the past and redesigned!!! :banghead: jetweb 10-22-2004, 09:08 PM Piston slap is good That means you have forged pistons They need more clearance because they expand get the car hot and it should go away I replaced my 87 cast pistons with Manley flat tops with two valve notches run them up to zero deck height and 66 cc alum heads around 10.7 to 1 compression ratio car flies and gets almost 30 mpg The 87 came with low compression and got 25 mpg After i did it they also changed the factory cars but mine is faster because it has ported heads a SLP cam with Pro flow cut back valves tri flow stainless exhaust I may sell it if anyone is interested got a bad back and it is to low to get out for me needs new mufflers and a few minor things 8k takes it 60k on it Automotive Network, Inc., Copyright ©2012
