RB26 swap to a R32 GTS-4
cheesey1x
09-21-2004, 01:29 PM
Iwas looking into doing a swap to an RB26 into my R32 Gts-4.. what are the differences and what all do i need other than the obvious? Is the engine harness and engine mounts the same? If any one could shed some light on the matter please do let me know. Or better yet if someone has experience doing so..
Thanks
Cheesey_boi
RazorGTR
09-21-2004, 11:45 PM
Mounts on the RB26 are alloy, the ones to the block. Other than that they are identical. It will bolt right up to your trans so no drama's until you plan on pushing some serious hp as in above 450hp then your trans won't last long if at all.
The looms are different, so is the coil pack loom, the ecu is totally different, and fuel pump. If you're getting a complete engine it is the best option or you will have to do the fuel pressure reg also. Exhaust is totally differnt to the cat.
