Re: Cherokee 95 engine whine
if the noise is coming from the front center of the engine it may be your water pump which is right there. With the car off and cold grab the water pump pulley and see if it moves side to side (not around ;-) ). if it moves it needs to be replaced. Water pumps are known for giving you hints before they buy the farm, noises, very very small leaks out the seep hole, etc. It's easier to tell this with the belt off but that can be a huge pita! :-)
If you want to get a belt and change it first, check the pump pulley for play while you have the belt off. if it's loose get it replaced. you'll be happy you did when your still driving down the road!
John Harris
http://www.electra225.com
"Problems are just solutions in work clothes"
