Gasket reusable?
19RaVeN96
09-19-2004, 01:52 AM
I need help. I was wondering if anyone new whether or not the gasket that is for the valve cover to connect if reusable. I took the old valve cover off and put on a new one. Can I use the pre-existing one? I have a 96 accord 4cyl. Any help would be appreciated.
AccordCodger
09-19-2004, 06:50 AM
No don't re-use it. You're just setting yourself up for leaks and having to do the job over again.
94accordVTEC
09-20-2004, 09:43 AM
NEVER re-use any gaskets it will just end up costing you more money when stuff starts to break because the gasket is leaking
ProMan
09-20-2004, 11:46 PM
This is a general mis-understanding for most people. The fact is, YOU CAN RE-USE THE VALVE COVER GASKET! As long as it's not hardened and brittle and have cracks. I had reused the gasket on my 92 Accord 2 times since it's still flexible and in "rubber condition", and it never leaks. Just make sure you apply sealant at the sharp corners.
nittanys1
03-09-2005, 03:24 AM
where can you go about getting the sealant? and how much will be needed?
jeffcoslacker
03-09-2005, 08:57 AM
The new gaskets with an integral carrier and silicone sealing beads seem to hold up real well to reuse. I wouldn't reuse a neoprene of cork gasket, or any composite of the two.
jeffcoslacker
03-09-2005, 08:59 AM
P.S. Never use sealant on a silicone type gasket. It acts as a lubricant, makes the gasket want to slip or migrate out of position once put in compression.
ProMan
03-09-2005, 11:23 AM
I always use a high temperature sealant. I do not have the name on hand. Will get it later. It's gold-orange color. I used it on oil pan, plug tube, vlave cover, etc. The amount you need to apply depends. Just make sure it's enough to form a thin layer along the surface that needs to be sealed.
You can get it at most auto parts store.
